Empty RFID status screen
  • Empty RFID status screen
    Hi all!
    I'm a new owner of an iAutomate RFID product. I installed the plug-in using Homeseer updater. After a few adjustments, i was able to have my (only) reader recognized by Homeseer:
    2006-11-10 18:26:08 iAutomate RFID RESTART REQUESTED - RESETTING THE RFID NETWORK
    2006-11-10 18:26:14 iAutomate RFID Network successfully reset - please wait for network enumeration and configuration to complete.
    2006-11-10 18:26:33 iAutomate RFID Reader Status:
    2006-11-10 18:26:33 iAutomate RFID Reader 1 (Location Reader) is at Node 1 with an RSSI of 0 and a gain that is LOW
    2006-11-10 18:26:33 iAutomate RFID There is 1 reader on the network.
    2006-11-10 18:26:34 iAutomate RFID Setting RSSI for node 1 to a value of 60
    2006-11-10 18:26:35 iAutomate RFID Setting GAIN for node 1 to a value of HIGH GAIN
    2006-11-10 18:26:35 iAutomate RFID Receiver Gain was changed successfully for Reader 1, Node 1
    2006-11-10 18:26:40 iAutomate RFID iAutomate RFID Startup Complete.
    When i click on the "RFID status" button, all i get is a RFID logo and an empty grey box with no information. Anyone has a clue of what i'm missing here? Do i need to install extra utility software?
    Thank you!
    Richard
    Server: HomeTroller S4
    Technology: X10, Insteon, iAutomate RFID, W800RF32
    Welcome,
    You need Java v 1.5 or later; please see:
    http://board.homeseer.com/showthread.php?t=109303
    Peter
    Originally posted by seguinr
    Hi all!
    Thank you!
    Richard
      Re
      Thank you Peter,
      i installed JAVA 2 v1.5.0 and my RFID status screen improved a bit...
      no information is available in the box. I have registered one reader and one tag sor far, but none of them are displayed.
      Thank you!
      Richard
        What version of RFID Status shows in bottom right ?? It is cut off in your image.
        Also, have you emptied your browser cache and restarted the PC ?
        Let me know
        Peter
        Thank you Peter,
        Thank you!
        Richard
          Hi Peter,
          i cleared IE cache and restarted my computer yesterday, but no change. This morning, i tried again and it worked (didn't reboot since yesterday)! However, the label "Reader/Tag Name" is still missing the leading "R" (see previously attached picture), should it be a concern?
          Thank you!
          Richard
            By chance are you using https for your homeseer access?
              Karib,
              the address starts with "http://localhost:..."
              Richard
                You forgot to answer my Question about the version of RFID Status.
                Second Question: What resolution is the monitor set to ?? Please post the whole image of the RFID Status, not an edited image.
                Peter
                Hi Peter,
                Thank you!
                Richard
                  Hi Peter,
                  sorry, i forgot to mention the version on the bottom right of the box is 1.3. My screen resolution is 1280 * 1024. I can't attached the whole screen because limits are set by the message board (approx. 600*800). Is there other ways to include images?
                  Thank you!
                  Richard
                    Richard,
                    Just wanted to check, I was bit by the same issue but I was using https
                    Joel
                      Just capture the whole image, then resize the whole image before you post (scale it)
                      Does the machine you are using have a Firewall or Antivirus app that prevents java or scripts from running ??
                      Can you give me remote access by sending me a private message for username and pw ??
                      Peter
                      Hi Peter,
                      Thank you!
                      Richard
                        I looked at your RFID Status remotely with the Guest Access that you provided to me and it is working OK here, so I suspect that there is a problem with the PC that you are viewing the RFID Status Screen with.
                        I saw three tags behaving normally at one reader.
                        This could be a java issue, or a security/permissions issue. What browser are you using ?? Is the OS using another language other than English ?
                        I also noticed that your Tag Types are not properly set, but I could not adjust as a guest.
                        Once you correct the tag type, you MUST restart our plugin.
                        Peter
                          Thank you for your visit!
                          I'm using IE 6.0 and yes, the O/S language is set in french. As for tag's types, they disappear once in a while. I entered the information, only this time, i made sure to click on "reset/restart everything"... we'll see if everything stay still, especially if a need to reboot.
                          I'll dig more on the security aspect, and everything related to Java.
                          Richard
                            Patch to 1.3.4 Posted
                            http://board.homeseer.com/showthread.php?t=117766
                              Hi Peter!
                              Thank you for the update. I ran the updater and rebooted my computer, but it seem to make no difference on the version of the utility: it's still old v1.3. In Homeseer's log, i've notice "updater warning" during the process:
                              2006-12-12 21:39:01 - Updater - Starting installation of updates
                              2006-12-12 21:39:01 - Updater - Applying update: iAutomate RFID
                              2006-12-12 21:39:07 - Updater - Extracting files from zip file: WebHelp.zip
                              2006-12-12 21:39:09 - Updater - Extraction Complete.
                              2006-12-12 21:39:09 - Updater - Extracting files from zip file: RFIDstatus.zip
                              2006-12-12 21:39:10 - Updater - Extraction Complete.
                              2006-12-12 21:39:10 - Updater - Copying file: C:\Program Files\HomeSeer 2\Docs\iAutomate RFID\Tag Polarization for Maximum Range.pdf
                              2006-12-12 21:39:10 - Updater - Copying file: C:\Program Files\HomeSeer 2\Docs\iAutomate RFID\hspi_RFID License & Disclaimers.pdf
                              2006-12-12 21:39:10 - Updater - Copying file: C:\Program Files\HomeSeer 2\Docs\iAutomate RFID\iAutomate RFID Manual for HomeSeer.pdf
                              2006-12-12 21:39:10 - Updater - Copying file: C:\Program Files\HomeSeer 2\Docs\iAutomate RFID\iAutomate RFID Scripting.pdf
                              2006-12-12 21:39:10 - Updater - Copying file: C:\Program Files\HomeSeer 2\Docs\iAutomate RFID\R500HA Easy Wiring Guide.pdf
                              2006-12-12 21:39:11 - Updater - Copying file: C:\Program Files\HomeSeer 2\Docs\iAutomate RFID\R500 Cable Terminations.pdf
                              2006-12-12 21:39:11 - Updater Warning - File exists, not overwriting: C:\Program Files\HomeSeer 2\Scripts\iAutomate_TagBattery.vbs
                              2006-12-12 21:39:11 - Updater Warning - File exists, not overwriting: C:\Program Files\HomeSeer 2\Scripts\iAutomate_TagStatus.vbs
                              2006-12-12 21:39:11 - Updater Warning - File exists, not overwriting: C:\Program Files\HomeSeer 2\Scripts\iAutomateRFID.vbs
                              2006-12-12 21:39:11 - Info - Un-registering C:\Program Files\HomeSeer 2\hspi_RFID.exe with Windows
                              2006-12-12 21:39:12 - Info - Wave OUT id: 3
                              2006-12-12 21:39:13 - Updater - Copying file: C:\Program Files\HomeSeer 2\hspi_RFID.exe
                              2006-12-12 21:39:15 - Updater Error - Unable to install files, is HomeSeer running? Please exit it now if so. (Retry in 5 sec.)
                              2006-12-12 21:39:15 - Info - Found Hi-Phone audio device: Hi-Phone Desktop USB
                              2006-12-12 21:39:20 - Updater - Copying file: C:\Program Files\HomeSeer 2\hspi_RFID.exe
                              2006-12-12 21:39:21 - Info - Registering C:\Program Files\HomeSeer 2\hspi_RFID.exe with Windows
                              2006-12-12 21:39:23 - Updater - Installation of updates completed
                              Should i install manually?
                              Thanks!
                              Richard
