Is scripting still available?
    Hi, I used scripts with iAutomate RFID plugin in HS2. Is it possible to use scripts with this new HS3 version? I don't see any references to scripting in the manual.
    Server: HomeTroller S4
    Technology: X10, Insteon, iAutomate RFID, W800RF32
    http://board.homeseer.com/showthread.php?t=160063
    tenholde
    tenholde
      Sorry if my previous post wasn't clear. I want to know the methods and properties of iAutomate RFID for scripting. It was documented with HS2 version, but I don't see that in the latest release.
        Scripts were never intended to be the primary interface between the RFID system and HomeSeer and I'm not sure what carried over to HS3. We'll test a few, but for the time being, I think you can make the following calls for JSON results:
        http://(server)/RFIDGetData?Command=Value
        Command is NOT case sensitive, so in these examples you do not need to put it exactly as I have it.
        http://(server)/RFIDGetData?GetReaders=
        Returns all of the readers found JSON encoded - which means you have to wait until the discovery of all of the readers is finished or it will return "No Readers Found".
        http://(server)/RFIDGetData?GetReader=X
        Same as above except it only gets Reader #X
        http://(server)/RFIDGetData?GetAllTags=
        Returns all of the tags at all of the readers JSON encoded. If there are none, it returns "No tags found" or something like that.
        http://(server)/RFIDGetData?GetTagsAtReader=X
        Same as above, except just the tags at reader #X.
        http://(server)/RFIDGetData?GetTag=XXX
        Same as above except it only gets Tag #XXX at all readers
        Update: All the scripting functions in the HS2 iAutomate RFID Scripting.pdf still exist except for GetTagCount or GetTagByIndex
        So you can use either the old scripts or the new JSON API.
        We'll edit the document this week and post a link to download the PDF.
        Peter
