I broke it
  • I broke it
    I installed the HS3 plugin on my HS3 system. I managed to, I think, get my readers set incorrectly. I deleted all the readers using the config tool, but in the log it is showing three readers, but two are reader 0 with different nodes? Probably due to my failing to reboot between each reader configuration.
    Can the readers be reprogrammed correctly?
    iAutomate RFID iAutomate RFID Startup Complete.
    iAutomate RFID -- Automatic Reset/Retry will occur in 1 minute --
    iAutomate RFID
    iAutomate RFID There are 3 readers on the network.
    iAutomate RFID
    iAutomate RFID Reader 1 ( ) is at Node 3 with an RSSI of 50 and a gain that is LOW
    iAutomate RFID Reader 0 ( ) is at Node 1 with an RSSI of 60 and a gain that is LOW
    iAutomate RFID Reader 1, Node 3 has a Receiver Gain that is LOW
    iAutomate RFID Reader 0, Node 2 has a Receiver Gain that is LOW
    iAutomate RFID Reader 0, Node 1 has a Receiver Gain that is LOW
    iAutomate RFID Network successfully reset - please wait for network enumeration and configuration to complete.
    iAutomate RFID Auto Polling was successfully DISABLED.
    iAutomate RFID RESTART REQUESTED - RESETTING THE RFID NETWORK
    You'll have to try to delete two of the readers in HS, then disconnect readers at node 2 and node 3 and then restart Homeseer with only node 1 connected to the serial port.
    Then connect a reader at node 2 location. Then add reader 2 in HS, save and restart HS.
    Then connect a reader at node 3 location. Then add reader 3 in HS, save and restart HS.
    You should see the enumeration occurring at each startup
    If this does not work, please email us directly and we will access your system remotely.
    Andy
    iAutomate RFID
    iAutomate RFID
      Well,
      I contacted Support@iautomate.com and Andy was able to log into my system and correct the configuration problems with the three readers. It was not something that I could have done on my own. Their support was terrific.
