Tag Out of Range for HH:MM:SS Trigger
  • pmonahan
    If you have questions about the Tag Out of Range for HH:MM:SS Trigger, please post in this thread.
  • pmonahan
    You have commented on a post that is almost two years old, I think. The written remarks have us confused.
    In addition, we need to know your version of HS, the version of RFID plugin, your OS etc.
    We also need the tag log for the entire period of time that the Trigger was being evaluated. In your example of 5 min, we would need a log for the period just before the tag left (Showing the tag detected), spanning 5 minutes, plus one minute beyond.
    Originally posted by bufflo View Post
    I'm having the same problem. Here is my event. I have also attached an image of the event.
    Event Name: Type Group Reassign:
    Submit
    SusanIsAway
    Run the event actions. Note that the event trigger is ignored. Event is enabled, click to disable. Edit all parts of this event. Delete this event. Copy this Event. Submit
    IF Tag Susan has been out of range of Attic Reader#1 for 0days 0hours 5min 0sec Submit Submit Make changes to this trigger or condition. Submit Add a trigger or condition.
    Then
    Set Device Motion House Occupied Susan to Off
    Submit Submit Make changes to this event action. Delete this action. Add an action.
    Set the Desired Event Options Here:
    Priority Event Include in Powerfailure Recovery
    Security (Randomize Time Triggers) Remove This Event After Triggering Do Not Log This Event
    Cannot Re-Run For: 0 Days 0 Hours 0 Minutes 0 Seconds
    Edit Time Span
  • bufflo
    Originally posted by pmonahan View Post
    We are unable to duplicate on two different HS3 systems. The trigger you reference fires every time.
    Can you post the Entire event with conditions, or email us a screenshot to support@ please?
    Submit
    SusanIsAway
    Then
    Edit Time Span
  • VirtualPanther
    Peter,
    I currently have two installations of HomeSeer: one is on a dedicated silent industrial PC (primary install) and I also maintain an up-to-date backup on a virtual Win8x64 machine. If the primary PC is down, I boot up the VM copy and automation goes on
    The Z-Troller, having a serial connection, is connected to either version of HomeSeer via Serial-to-Ethernet Global Cache device. This way, I can easily bring up the cloud backup, without having to physically be home and disconnect/reconnect things.
    Here is where I come to iAutomate. My 1-2 y.o. iAutomate RFID stuff is serial-based, as you are well aware. However, your plugin for HS3 only allows to choose a Com port, as a method of connection. Does that mean that unless the hardware is physically connected to a physical PC with a serial port, I can't use it at all?
  • pmonahan
    Originally posted by k1pp3r View Post
    The only issue i have is the trigger "Tag out of range for xx time" does not seem to retrigger after it has triggered once.
    I used a workaround by using "Tag leaves range of reader, start timer" Its not ideal, but it works and seems more stable.
  • k1pp3r
    If you report suspected issues to us via email, we can test and address as necessary. We'll try to duplicate here.
    Peter
    I had planned to, just wasn't a priority since the work around seems to actually work really well with the timers.
  • pmonahan
    started a topic Tag Out of Range for HH:MM:SS Trigger
    Same here!
    I held off on HS3 for the iAutomate plugin, which works ok. The only issue i have is the trigger "Tag out of range for xx time" does not seem to retrigger after it has triggered once.
    Peter
