Contacting HomeSeer This Week
See more
See less
BLRoombaWifi
This is a sticky topic.
  • Can you turn on debug logging and capture that happening
    Then turn off debug logging and attach the log zipped
    Cheers,
    Bob
    • Bob, the graphic at the top was set to "Genny" then when I went to Lucie event and changed the its name to Lucie, Genny's event changed to Luice. Mike
      Computer: CUK Intel NUC7i7BNH
      Op System: Windows 10 Pro - Work Station
      HS Version: HS3 Pro Edition 3.0.0.435
      Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
      • Hmmm ok - let me check into it
        Cheers,
        Bob
        • Bob, This sounds a lot like "No good deed (your efforts) goes unpunished!", Mike
          • Yea it would not be the first time lol
            Try out 2.0.29 in the beta section
            I would delete the existing events first, then load the beta and re-create them
            It is hard for me to test because I only have one Roomba
            Let me know
            Cheers,
            Bob
            • Bob, sorry for the lag in response, v.29 works as advertised, I just purchased a 3rd Roomba (i7) I noticed that when I attempted to get the password of the i7 the Dorita screen was abbreviated from my usual 980 display but it did provide the i7's password. I also noticed that my two 980 populated their devices immediately, but the i7 did not sure if there's something I need to do in order to wake the i7 up? (tomorrows problem). One additional observation is that after you add a new Robot you are unable to modify the Password field in any Roomba Robot also the password field nomenclature is missing. Mike
              • Try out 2.0.30 in the beta section - should fix password issue
                Cheers,
                Bob
                • Bob, have downloaded your v.30, and now see the "Password:" nomenclature +1, however if you hover and select your cursor over the Password field (in order to update it) you do not get a "Edit Value" box to change/update ones Password. I do get "Edit Value" boxes for Name:, IP Address: and Username/Blid: and have confirm the same for my two other Roomba Robots.
                  i7 Roomba still doesn't seem to communicate with Roomba PI, it does create the same devices (as expected) but the i7 Robot devices are all empty even though I can communicate with the IOS app and command the i7 to do all things it looks like S/W version 1.6.6 is the latest for (Aug 19) also it appears that the Clean Base (base plus vacuum) has software associated with it S/W version is 0.10.20 for (Aug 19). Mike
                  • Well that is odd - mine does it too
                    It works on an add for me
                    Very odd
                    Cheers,
                    Bob
                    • Try 2.0.31 in the beta section
                      Cheers,
                      Bob
                      • Bob, ver .31 seems to have solved it, I had posted this issue some time ago and simply worked around it by deleting and re-adding the affected Robot, this make life simpler, many thanxs for the updates, Mike
                        I noticed that you avoided my 2nd enquire re i7, any thoughts (other than PIA)? Mike
                        • I am not sure right now why the i7 does not communicate - the plugin was written for the 980 originally and I am sure that Roomba must use the same interface to them
                          Can you capture me a debug log of the plugin startup
                          1. Disable plugin
                          2. Edit BLRoombaWifi.xml and change debugLevel to true and save the xml file
                          3. Re-enable the plugin
                          Let it run for a few minutes then disable debug logging and attach the log zipped
                          Cheers,
                          Bob
                          • Bob, as per your request... if you need more please do not hesitate to ask..
                            • That debug log contains stuff from yesterday
                              Can u delete it and then capture it again
                              Also make sure you done the steps in this thread
                              https://forums.homeseer.com/forum/3r...-debug-logging
                              Cheers,
                              Bob
                              • Sorry Bob, I got hung up with Admin rights could not delete the BLRoombaWifi-detail file (learning curve) I believe I now have a proper file, Mike
