BLRoombaWifi
This is a sticky topic.
    Which one of your roombas is the i7?
    Cheers,
    Bob
      Rosie (Down Stairs) - Username/Blid:1DC00179C5B947F6934DEB11
      Computer: CUK Intel NUC7i7BNH
      Op System: Windows 10 Pro - Work Station
      HS Version: HS3 Pro Edition 3.0.0.435
      Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
        The connection is being refused to the i7. The MQTT library is not reporting an exception but the the object is not connected
        Cheers,
        Bob
          Try out 2.0.32
          I added more debug logging
          Delete the debug log and capture the same log
          Cheers,
          Bob
            Ok Bob, firstly thanxs for taking the time to investigate. English please so the connection issue is re the Roomba PI or something else and more importantly is there a possible fix? Mike
              Bob, question relating to the BLRoomba Connectivity Trigger is there a frequency when the trigger is issued or is it on a change basis? The reason I asked is that I created a Virtual Device that has two state Connected or Not connected which is toggled depending on Connectivity Trigger, I noticed that when I change it from On to Off it seems to stay Off even though it is really still connected. Mike
                It runs the trigger on connect or a connect failed attempt to the roomba
                Try out 2.0.32
                Cheers,
                Bob
                  Bob, per your request..
                    OK the return back from the MQTT connect is 2 which is this:
                    CONN_REFUSED_IDENT_REJECTED
                    Looks like it could possibly be the username or password or both
                    Cheers,
                    Bob
                      I noticed when I did my Dorita980 on the i7 Roomba I got an abbreviated return (see attached) which only contained the password (this was noted by another i7 user via post) so in order to get the username I went to my UniFi Clients which gave me the Hostname see attached
                        I also noticed that when I look at my 980 Roomba the hostname is Roomba followed by the username (numbers after the dash) which is the same as what I used for the I7. Mike
                          Bob, any suggestions? Mike
                            I cannot think of anything right now
                            I wonder why dorita does not return the user name
                            Cheers,
                            Bob
                              Bob, I've figured it out re Dorita980. In my procedure for the 980 I had the following command: in the “Command Prompt” screen Type “node .\bin\getpassword.js 192.168.1.XXX”, and enter, however this procedure with the i7 will only produce the password. Soo... for the i7 the following command must be use to produce both correct userid and password same output as 980;in the “Command Prompt” screen Type “get-roomba-password 192.168.1.XXX”, and enter.
                              What I discovered is that my blid was slightly different it started out correctly but was short 8 additional characters at the end. I then deleted my prior Roomba in the Plug-In and its' associated devices and re-added a new Roomba as normal with the correct blid and password and Wala! now working i7 Roomba devices. As always a learning moment, thanxs Bob for all the support and time I hope this helps the next person trying to navigate all things npm, I will update my previous procedure to reflect the changes. Mike
                                No problem - glad you got it working
                                Cheers,
                                Bob
