Roomba i7+
  • Roomba i7+
    Will the plugin be updated to include the new i7+ model? this new i7 model with the dump bin is what I've been waiting on for the development team to roll out.. I'm hoping these new feature become available in the plug-in...
    Many thanks in advance..
    Devoir
    Devoir
    +1 for this! Going to be getting an i7 in a week!
    Plugin's:
      I just got that as well, but without the dump bin (for now). will it not work with the standard i7?
        I can confirm that this does work (with some effort to get the ID and Password) for the i7. Again, I don't have the dump bin (yet)…
          I got my i7 working with very little effort (iRobot firmware 1.6.6). Running Node.js on Windows 10. Installed dorito980 (via npm), ran the getpassword script, got the BLID and password, put it in the plugin option.....hey presto.
          I did update the i7 firmware first. V1.6.6 was downloaded. Apparently V2+ is slowly being rolled out, so you have to wait for that. I already had Node.js on my machine so not much effort there. Did struggle to find where npm downloaded the dorito980 files but found them in C: windows/system32/node_modules. The rest was as per the instructions.
          I do actually have the i7+ base unit/dump bin but haven't been able to use it as I got the robot from the USA (110vac) and I live in NZ (240vac). Am awaiting the arrival of a suitable step down transformer. The base is not an international appliance and I need a step-down capable of 1200watts (according to the specs on the base unit). Yikes. Luckily my old Roomba base charger works with the i7 which is fine in the mean time.
          iCore5 Win 10 Pro x64 SSD
          HS3 Pro Edition 3.0.0.435 Windows
          BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
            Ok i dont have a degree in anything related to computers, but I did manage to find doritA980. It downloads in a zip file. I also downloaded and installed node.js. I read the readme file but the install instructions are 1 line and they dont make sense to me.
            Do I type ```bash?
            or is that implying to bash keys?
            Any pointers? Maybe a quick youtube or screenshots? Us laymen appreciate the help, thanks!
              Do I type ```bash?
              What operating system are you using? Windows?
              If you are running windows and install node.js it will automatically install the npm package manager.
              Instructions for windows are in this post: https://forums.homeseer.com/forum/ro...88#post1123188
              or here https://forums.homeseer.com/forum/ro...80#post1272580
              If you get stuck I can put up step by step instructions.
              M
                M
                Thanks for that! The link you provided for windows instructions got me through the process. Only hang up I had was learning to replace 192.168.0.XXX with the actual IP of my roomba. Rookie mistake I know.
                My i7 Roomba is now functional via Homeseer.
                I did have to disable the BLRoombaWifi plugin and kill it via task manager because I was still seeing 100% cpu load. After that, re-enabling the plugin with its newly updated user and pwd fields has resulted in a stable 2% cpu load which is normal.
                Thanks again, I hope other people in a similar circumstance can benefit reading these posts.
                  Glad you got it up and running. That's the great thing about the HS community. All sorts of people with different skill sets helping each other out.
                  Just remember that if you update the firmware on the robot you will have to use the dorita980 script to get the new BLID and new password.
                  M
                    Followed the windows instructions and had my i7+ into HS3Pro in minutes. Thanks for the entires in the forums. Huge help.
                      Adding: also had it up and going in a few minutes. Pretty cool. Thank you, all.
