Change Rooma Schedule
This is a sticky topic.
  • Change Rooma Schedule
    As of build 2.0.34 (in beta section if not released), you will be able to change the Roomba schedule using a scripting call
    PLEASE NOTE:
    I have also fixed setting the preferences from the devices (carpet boost, etc)
    The scripting call is SetSchedule
    hs.PluginFunction("BLRoombaWifi", "", "SetSchedule", new Object(){"Sonny", "Monday=10:00,Tuesday=none,Thursday=11:00"})
    The 1st parameter is the roomba name
    The 2nd parameter is a string of days equal to the time or "none" - separated by a comma
    If you use none for a day of the week then that day will be disabled
    If you set the say of the week to a time (in 24 hour format), then the day of the week is enabled
    It will only change the days you specify
    PLEASE NOTE
    If you are using the Roomba i7, then you must pass in all days on the same line.
    For multiple times per day, separate them with a pipe (|) character
    hs.PluginFunction("BLRoombaWifi", "", "SetSchedule", new Object(){"Sonny", "Sunday=none,Monday=10:00|15:00,Tuesday=none,Wednesday=none,Thursday=11:00|16:00",Friday=none,Saturday=none})
    Cheers,
    Bob
    Thanxs Bob, I will play with it tomorrow, Mike
    Computer: CUK Intel NUC7i7BNH
    Op System: Windows 10 Pro - Work Station
    HS Version: HS3 Pro Edition 3.0.0.435
    Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
      Bob, what is the second set of "" after
      ("BLRoombaWifi",
      used for ?
        Bob, setup a manual event (see attached) when executed produced an error messages (see attached)
          Instead of starting the command with a &, start it with &n
          &nhs.PluginFunction("BLRoombaWifi", "", "SetSchedule", new Object(){"Genny", "Monday=10:00,Tuesday=none,Thursday=10:00"})
          Cheers,
          Bob
            Bob, that corrected the error and allowed to run. However it produced mixed results, apparently if you have days that you setup but are not in the command string what you asked to be changed changes but the previous items that weren't addressed remains (makes sense) so the proper command is;
            &nhs.PluginFunction("BLRoombaWifi", "", "SetSchedule", new Object(){"Genny", "Monday=10:00,Tuesday=none,Wednesday=none,Thursday=10:00,Friday=10:30"})
            I think we should add Saturday and Sunday and simply denote the days that are blank to "none" and the days that require start times inputted to avoid any un-intendant consequences, your thoughts, I'm assuming that the proper Roomba day starts with Sat and ends with Fri? Within the Plug-in you abbreviated the days due to device real-state? Do we need to have the complete day spelled out in the script? Mike
              You can use Monday or Mon as the day
              The call will only change what you pass to it - it will not touch the other days
              My Roomba goes from Sun-Sat
              Is yours different?
              Cheers,
              Bob
                Well whilst looking at my iRobot app, I have for i7 = S, M, T, W, Th, F, Sa and for 980 = Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday
                Found something interesting the latest script only works on Roomba 980 and not the i7, not sure why but I tried both ways e.g Sunday and S with not difference what I have in the "Weekly Schedule" device is "No schedule entered" any ideas Mike
                  Bob,
                  Exploring a little more into the i7 schedule is different than for 980; you can enter a Once with time which is self explanatory, the Weekly allows you to select what ever days of the week with one time being assigned for that schedule event you can enter multiple schedule events with same or different days and are able to assign a different time for that schedule event, does that make sense sooo.. me thinks that there's a different scheme for i7, Mike
                    Do this for me
                    1. Disable plugin
                    2. Edit the BLRoombaWifi.xml and change debugLevel to true
                    3. Restart plugin
                    Let the plugin run a couple minutes and then disable debug logging
                    Attach the debug log zipped to an email to me - just respond to an email I sent
                    Tell me which roomba is the i7
                    Cheers,
                    Bob
                      Done
