HS4 installation
  • HS4 installation
    Just want to be sure I set things up properly. Should I have to add the existing Roomba to the plugin when running the current HS4 beta? I am just running the plug-in found in the plug-in installer. I copied my HS3 database over and see the devices from HS3. Is there something else I can/need to copy over from the HS3 install to have this configured?
    My apologies if this is posted someplace.
    Karl S
    HS3Pro on Windows 10
    96 Devices
    54 Z-Wave Nodes
    37 Events
    Google Home: 3 Mini units
    this was just on my mind...
    so you copied over the database from hs3.. that is it? it created the devices in HS4? I want to add this next...
    thx
      I may have also copied the BLRoombaWiFi.xml file found in the config folder. I cannot recall. I also have since done a complete clean installation since a problem I had with HS3 and new events followed me to HS4, so I am not able to check date/time/size on the file to verify.
      Karl S
      96 Devices
      54 Z-Wave Nodes
      37 Events
        ahhh ok ill just do over then too...
