Any documentation?Error on running the plugin HusMow.
  • #16
    Can you post the log here, also what system are you using, Linux or Windows?
    • #17
      Sure
      Tried to filter the log..
      [spoiler]
      aug-19 16:38:44 Starting Plug-In Plugin HUSMOW started successfully in 7119 milliseconds
      aug-19 16:38:37 HUSMOWhusmow2 Initializing done! husmow2 Ready...
      aug-19 16:38:37 HUSMOWhusmow2 Starting initializiation.husmow2 HUSMOW Ver:3.0.0.15
      aug-19 16:38:37 Starting Plug-In Initializing plugin HUSMOW ...
      aug-19 16:38:36 Starting Plug-In HUSMOW loaded in 15073 milliseconds
      aug-19 16:38:22 Info Plugin HUSMOW with instance husmow2 has connected. IP:127.0.0.1:57826
      aug-19 16:38:21 Warning I/O interface HUSMOW is down, executable is not running, restarting ...
      aug-19 16:38:09 Info Plugin HUSMOW with instance: husmow2 has disconnected
      aug-19 16:37:56 HUSMOWhusmow2 ERROR newthread husmow2 Error: Thread is running or terminated; it cannot restart.
      aug-19 16:37:56 HUSMOWhusmow2 ERROR Get Mowers failed: System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'api.amc.husqvarna.dev' at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait() at HSPI_HUSMOW.Provider._GetMowers() at HSPI_HUSMOW.Provider.GetMowers() at HSPI_HUSMOW.Telnet.startS1() ---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'api.amc.husqvarna.dev' at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace ---<---
      aug-19 16:07:10 HUSMOWhusmow2 ERROR Get Mowers failed: System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'api.amc.husqvarna.dev' at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait() at HSPI_HUSMOW.Provider._GetMowers() at HSPI_HUSMOW.Provider.GetMowers() at HSPI_HUSMOW.Telnet.startS1() ---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: The remote name could not be resolved: 'api.amc.husqvarna.dev' at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Net.Http.HttpClientHandler.GetResponseCallback(IAsync Result ar) --- End of inner exception stack trace ---<---
      aug-19 10:08:56 HUSMOWhusmow2 Debug Hs trigger HUSMOWhusmow2 HUSMOW HUSMOW Automower 430X Start ref#:5256 to value: -2
      aug-19 10:08:43 HUSMOWhusmow2 Debug Hs trigger HUSMOWhusmow2 HUSMOW HUSMOW Automower 430X Start ref#:5256 to value: -4
      aug-19 10:07:59 HUSMOWhusmow2 Debug Hs trigger HUSMOWhusmow2 HUSMOW HUSMOW Automower 430X Start ref#:5256 to value: 0
      aug-19 10:07:58 HUSMOWhusmow2 Debug Hs trigger HUSMOWhusmow2 HUSMOW HUSMOW Automower 430X Start ref#:5256 to value: -4
      aug-19 10:06:16 HUSMOWhusmow2 Debug Hs trigger HUSMOWhusmow2 HUSMOW HUSMOW Automower 430X Start ref#:5256 to value: -4
      aug-19 09:08:31 HUSMOWhusmow2 ERROR Get Mowers failed: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_HUSMOW.CurrentPlugin.CreateDevice(String name, String id, String location1, String location2, String devic, String devicedesc, String Fonction, String zone, Boolean data)
      aug-19 09:08:31 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-E
      aug-19 09:08:31 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-S
      aug-19 09:08:31 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-A
      aug-19 09:08:30 HUSMOWhusmow2 ERROR Get Mowers failed: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_HUSMOW.CurrentPlugin.CreateDevice(String name, String id, String location1, String location2, String devic, String devicedesc, String Fonction, String zone, Boolean data)
      aug-19 09:08:30 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-B
      aug-19 09:08:30 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-T
      aug-19 09:08:30 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-M
      aug-19 09:08:29 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-P
      aug-19 09:08:29 HUSMOWhusmow2 ERROR Get Mowers failed: System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_HUSMOW.CurrentPlugin.CreateDevice(String name, String id, String location1, String location2, String devic, String devicedesc, String Fonction, String zone, Boolean data)
      aug-19 09:08:29 HUSMOWhusmow2 Creating device HUSMOWhusmow2-1-C
      aug-19 09:08:29 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-E
      aug-19 09:08:28 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-S
      aug-19 09:08:28 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-A
      aug-19 09:08:28 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-B
      aug-19 09:08:27 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-T
      aug-19 09:08:27 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-M
      aug-19 09:08:27 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-P
      aug-19 09:08:26 HUSMOWhusmow2 Creating device HUSMOWhusmow2-0-C
      aug-19 09:03:55 HUSMOWhusmow2 Warning Desable Connection HUSMOW
      aug-19 09:02:42 HUSMOWhusmow2 Warning Desable Connection HUSMOW
      aug-19 08:59:54 Plug-In Finished initializing plug-in HUSMOW
      aug-19 08:59:54 Starting Plug-In HUSMOW loaded in 7110 milliseconds
      aug-19 08:59:54 Starting Plug-In Plugin HUSMOW started successfully in 6914 milliseconds
      aug-19 08:59:47 HUSMOWhusmow2 Initializing done! husmow2 Ready...
      aug-19 08:59:47 HUSMOWhusmow2 Starting initializiation.husmow2 HUSMOW Ver:3.0.0.15
      aug-19 08:59:47 Starting Plug-In Initializing plugin HUSMOW ...
      aug-19 08:59:47 Info Plugin HUSMOW with instance husmow2 has connected. IP:127.0.0.1:55317
      aug-19 08:59:47 Plug-In Interface HUSMOW is running as a trial, 29 days remaining.
      aug-19 08:59:36 Error Getting web page from plugin page HUSMOWConfig:Object reference not set to an instance of an object.
      aug-19 08:59:27 Error Getting web page from plugin page HUSMOWConfig:Object reference not set to an instance of an object.
      aug-19 08:59:04 Error Getting web page from plugin page HUSMOWConfig:Object reference not set to an instance of an object.
      aug-19 08:58:38 Starting Plug-In Plugin HUSMOW started successfully in 6682 milliseconds
      aug-19 08:58:32 HUSMOW Starting initializiation. HUSMOW Ver:3.0.0.15
      aug-19 08:58:32 Starting Plug-In Initializing plugin HUSMOW ...
      aug-19 08:58:32 Info Plugin HUSMOW has connected. IP:127.0.0.1:54102
      aug-19 08:58:31 Plug-In Finished initializing plug-in HUSMOW
      aug-19 08:58:31 Starting Plug-In HUSMOW loaded in 100 milliseconds
      aug-19 08:58:30 Info Plugin HUSMOW with instance: has disconnected
      aug-19 08:58:12 Starting Plug-In Plugin HUSMOW started successfully in 6703 milliseconds
      aug-19 08:58:05 HUSMOW Starting initializiation. HUSMOW Ver:3.0.0.15
      aug-19 08:58:05 Starting Plug-In Initializing plugin HUSMOW ...
      aug-19 08:58:05 Info Plugin HUSMOW has connected. IP:127.0.0.1:53729
      aug-19 08:58:03 Plug-In Interface HUSMOW is running as a trial, 29 days remaining.
      aug-19 08:49:28 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_HUSMOW.exe.config
      aug-19 08:49:28 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Bin\HUSMOW\Newtonsoft.Json.dll
      [/spoiler]
      By some reason this didn't catch the credential errors..
      Errors below
      [spoiler]
      aug-19 10:08:56 HUSMOWhusmow2 ERROR Error while running trigger:
      aug-19 10:07:58 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:06:50 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:06:50 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:06:17 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:06:05 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:06:05 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:04:58 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:04:58 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:03:49 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:03:49 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:02:42 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:02:42 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:01:35 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:01:35 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 10:00:27 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 10:00:27 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:59:20 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:59:20 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:58:13 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:58:13 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:57:05 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:57:05 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:55:58 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:55:58 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:54:50 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:54:50 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:53:42 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:53:42 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:52:35 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:52:35 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:51:27 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:51:27 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:50:19 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:50:19 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:49:12 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:49:12 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:48:04 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:48:04 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:46:56 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:46:56 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:45:48 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:45:48 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:44:40 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:44:40 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:43:33 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:43:33 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:42:25 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:42:25 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:41:17 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:41:17 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:40:09 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:40:09 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:39:01 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:39:01 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:37:53 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:37:53 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:36:45 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:36:45 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:35:38 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:35:38 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:34:30 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:34:30 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:33:22 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:33:22 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:32:15 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:32:15 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:31:08 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:31:08 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:30:01 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:30:01 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:28:52 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:28:52 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:27:44 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:27:44 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:26:37 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:26:37 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:25:30 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:25:30 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:24:22 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:24:22 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:23:14 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:23:14 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:22:07 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:22:07 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:20:59 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:20:59 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:19:51 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:19:51 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:18:43 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:18:43 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:17:36 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:17:36 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:16:28 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:16:28 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:15:20 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:15:20 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:14:13 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:14:13 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:13:05 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:13:05 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:11:55 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:11:55 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:10:48 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:10:48 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:09:42 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:09:42 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:08:33 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:08:33 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:08:32 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:08:32 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:02:59 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:02:59 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:02:58 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      aug-19 09:02:58 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:02:49 HUSMOWhusmow2 ERROR Error Please check user, password and Client ID: error: 400 Bad Request
      aug-19 09:02:49 HUSMOWhusmow2 ERROR Invalid Token check user, password, Id client
      [/spoiler]
      Running Windows Server 2012 R2, latest patching was done this weekend, both on OS and HS3.
