After installation I get this error when I start the plugin:
Jun-09 1:30:51 PM Plug-In Finished initializing plug-in HUSMOW Jun-09 1:30:51 PM Starting Plug-In HUSMOW loaded in 3806 milliseconds Jun-09 1:30:51 PM Error Initializing plug-in(2): HUSMOW Instance::Object reference not set to an instance of an objectSTACK: at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI.InitIO(string) at Scheduler.clsHSPI.CheckInterfaces () [0x000c4] in <9d0c99dc968a48469ec86efcf4ea6794>:0 Jun-09 1:30:51 PM Info Plugin HUSMOW with instance: has disconnected Jun-09 1:30:51 PM HUSMOW ERROR newthread Error: Thread has already been started. Jun-09 1:30:51 PM HUSMOW ERROR newthread Error: Thread has already been started. Jun-09 1:30:51 PM HUSMOW ERROR Get Mowers failed: System.IO.FileNotFoundException: Could not load file or assembly 'System.Net.Http, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'System.Net.Http, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_HUSMOW.Provider.GetMowers () [0x00171] in :0 at HSPI_HUSMOW.Telnet.startS1 () [0x00055] in :0 Jun-09 1:30:51 PM HUSMOW ERROR Get Mowers failed: System.IO.FileNotFoundException: Could not load file or assembly 'System.Net.Http, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'System.Net.Http, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_HUSMOW.Provider.GetMowers () [0x00171] in :0 at HSPI_HUSMOW.Telnet.startS1 () [0x00055] in :0 Jun-09 1:30:51 PM HUSMOW ERROR Get Mowers failed: System.IO.FileNotFoundException: Could not load file or assembly 'System.Net.Http, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. File name: 'System.Net.Http, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at HSPI_HUSMOW.Provider.GetMowers () [0x00171] in :0 at HSPI_HUSMOW.Telnet.startS1 () [0x00055] in :0 Jun-09 1:30:50 PM Device Control Device: JowiHue JowiHue Toalett 1 etg to Off (0) Jun-09 1:30:50 PM Event Event Trigger "Lys Toalett 1etg - Auto off" Jun-09 1:30:48 PM HUSMOW Initializing done! Ready... Jun-09 1:30:48 PM HUSMOW Starting initializiation. HUSMOW Ver:3.0.0.15 Jun-09 1:30:48 PM Starting Plug-In Initializing plugin HUSMOW ... Jun-09 1:30:48 PM Info Plugin HUSMOW has connected. IP:127.0.0.1:57217 Jun-09 1:30:47 PM Plug-In Interface HUSMOW is running as a trial, 26 days remaining. Jun-09 1:30:43 PM Device Control Device: JowiHue JowiHue TV stue to Off (0) Jun-09 1:30:43 PM Event Event Trigger "Lys TV Stue - Auto off" Jun-09 1:30:11 PM Error Warning, Cannot load EXE (possibly missing dependencies) HSPI_HSBuddy.exe: Could not load type of field 'HSPI_HSBuddy.Cameras.IpCamera:client' (1) due to: Could not load file or assembly 'System.Net.Http, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Jun-09 1:30:06 PM Updater Install/Update of package Husqvarna Automower was successful. Jun-09 1:30:06 PM Updater Copying file: /usr/local/HomeSeer/HSPI_HUSMOW.exe.config Jun-09 1:30:06 PM Updater Copying file: /usr/local/HomeSeer/HSPI_HUSMOW.exe Jun-09 1:30:06 PM Updater Copying file: /usr/local/HomeSeer/Bin/HUSMOW/Newtonsoft.Json.dll Jun-09 1:30:06 PM Updater Installing package Husqvarna Automower Jun-09 1:30:06 PM Updater Update hspi_husmow.exe downloaded successfully Jun-09 1:30:03 PM Updater Downloading update: Husqvarna Automower Jun-09 1:30:03 PM Updater Starting download of updates
Any idea?
Any idea?
