Screenshots
This topic is closed.
This is a sticky topic.
    Screenshots
    Some screenshots of the JLR plug-in. Note that not all devices and/or options are available on all vehicles.
    First the main car attributes like make, model, model year, body etc. You can change the nickname and registration info here as well:
Name:	21 attributes.png
    Next the status devices, that holds the current status, alerts, errors and actions. You can also lock and unlock your vehicle, honk & flash, reset (turn off) the alarm, set a wakeup timer, enable/disable journeys (trips) and enable/disable transport or service mode:
Name:	22 status.png
    Below are the devices for a Full Electric vehicle (currently I-Pace only). Charging options, battery status, and preconditioning:
Name:	23 electric.png
    Some devices that holds the current position of the car. Depending on the model, it might only support the last parked location:
Name:	24 position.png
    You can add, edit, and delete the timers with the Departure Timer devices below. Make sure to Save when you have created a new timer or edited an existing one. This part of the API is really unstable and might take several “Saves” to save. The Status device should give you some feedback on the (un)successful save attempt:
Name:	25 timers.png
    And finally, the Trip devices. Depending on the configuration, it can hold your last 1000 trips (or more, but I was unable to test). Eco, consumption and regeneration devices are only created for full electric vehicles (currently I-Pace only):
Name:	26 trips.png
    stefxx
