Release notes
This topic is closed.
This is a sticky topic.
    Release notes
    Release 4.0.6.0, 23-10-2020
    • Fixed Error and Alert string and value
    • Fixed SSL issue
    Release 4.0.0.5, 02-07-2020
    • Fixed missing image for “Map” feature
    • Added category
    Release 4.0.0.4, 18-05-2020
    • Fixed “Dustbin” status
    • Fixed “Error” status in Maps view
    Release 4.0.0.3, 10-02-2020
    • Update PluginID
    Release 4.0.0.2, 06-02-2020
    • Fixed issues with plugin start, stop and status
    Release 4.0.0.1, 28-01-2020
    • Fixed Zone devicestring and dropdown (show zone name instead of value)
    • Fixed token refresh without authorization key
    • Fixed robot replace
    • Fixed plugin icon
    Release 4.0.0.0, 22-01-2020
    • Initial HS4 version
    Release 3.0.0.14, 02-11-2019
    • Reformatted Secret Key in config pages (new models use 256 key length)
    • Added support for Imperial units
    Release 3.0.0.13, 23-06-2019
    • Added preferences support for robotSounds (supported models only)
    Release 3.0.0.12, 02-04-2019
    • Fixed device images
    • Fixed Parent/Child device relationship
    • Added Robot replace function
    Release 3.0.0.11, 18-03-2019
    • Fixed 404 error when secret_key changed (for instance, due to a re-registration of same Robot)
    • Added confirmation to "Remove all Neato devices"
    • Added "Refresh all Neato devices" as additional troubleshooting option
    Release 3.0.0.10, 29-01-2019
    • Improved error messaging during connection failures
    • Added multiple persistent map and zone support (supported models only)
    Release 3.0.0.9, 04-01-2019
    • Fixed errors when non-supported devices are registered on a Neato account
    • Fixed Eco/Turbo/Deep options (due to firmware change) for D7 and possibly other affected models (new installs only)
    Release 3.0.0.8, 07-12-2018
    • Added support for the Neato D4 connected and D6 connected
    • Fix for Map cleaning (due to firmware change) for D7 and possibly other affected models
    Release 3.0.0.7, 02-09-2018
    • Fixed the "Active" indicator on the config page
    Release 3.0.0.6, 10-06-2018
    • Fixed crash when robot is not responding during initial setup
    • Improved connection with Neato cloud and better handling of errors
    • Differentiate between Offline (-1) and Robot offline (-2) in Status device
    • Display connection errors in log now optional (default=off)
    • Optionally log to file (instead of eventlog)
    • Check and report if another version of Newtonsoft.Json.dll is found
    Release 3.0.0.5, 17-05-2018
    • Added "Active" indicator for each robot on the config page
    • Moved map images to a unique directory for each robot (html/NeatoMaps/#serial)
    • Fixed invalid Map #0 from selection
    • Fixed map retrieval after cleaning session
    • Fixed NavigationMode setting
    • Fixed several Linux related issues
    Release 3.0.0.4, 11-05-2018
    • Added quick selection of available maps
    • Changed LastUpdate of Map devices to reflect actual end-time
    • Added Pause before Dock for devices that cannot Dock without Pause first
    • Fixed crash when unknown robot error is returned from API
    Release 3.0.0.3, 27-04-2018
    • Added Maps (and map history) including statistics
    • Added (much) better icons all devices
    • Added more descriptive alert and error messages (firmware 3.x and up)
    • Moved settings to a new root device
    • Removed "Map" button on devices that do not support virtual no-go lines
    • Several minor fixes
    Release 3.0.0.2, 24-04-2018
    • Added Mode, Modifier, NavigationMode, SpotWidth and SpotHeight
    • Added Persistent Map cleaning
    • Fixed DirtbinAlertReminder, FilterChangeReminder and BrushChangeReminder
    • Added Token Refresh (security)
    • Stability improvements
    Release 3.0.0.1, 20-04-2018
    • Fixed bin/Bin Linux dll issue
    • Fixed crash at startup with Botvac Connected
    Release 3.0.0.0, 17-04-2018
    • Initial version
    stefxx
