Warning : The plugin object not available.
To remove any orphaned/corrupt/bad vehicle configurations, you need to a) delete them from the vehicles page and b) delete any devices in HomeSeer that the plugin created. Then restart the plugin and you should have a clean slate. I will need more information (all the normal stuff in the "Having trouble?" post like log files, etc.) if this still doesn't work, since it does now seem to be working in general for others.
The plug-in is still not working. I tried to delete everything related to the program. Restarted my system and pc. Installed it again. Stil the same, no update on the vehicle.
After I deleted and re installed it, it showed up on the plug-in page with the two vehicle from the past installation, I do not know why it does not uninstall the old config, even I did it manually in the config, log and HS3 folder.
This process I did around 5 or 6 times, with no luck.
What to do ?
Originally posted by will40 View Post
Fix works. As a feature request can that location device string state the address if it is not a known location? If tough to do no problem and certainly no rush. I can add a virtual device with Bing script but let me know if its possible?
Originally posted by shill View PostJust noticed the same thing for me as well. Probably a simple fix I can put in tonight. (I was so focused on figuring out how to handle the UI of picking a location, I guess I should have done more testing on the actual device updates... sorry about that!)
all is working good for me with the exception of the location update. It has not moved from my known location since I installed yesterday although the GPS coordinates have been updated twice and have recently updated to my current location.
Unless you're testing out a fix here on the forums for a problem I can't recreate on my own system, all you ever need to do is get the latest and greatest from the updater. When that becomes available is always some delay after I publish it, since someone from HST has to approve and deploy it.
(Edit: And for any plugin, stop it first and check your server's task manager to ensure the process is no longer running before clicking the "Download and install" button.)
Hi Steve "I fixed that" does it mean it is fixed in the updater, should I try with a new install. Last time I manually deleted Tesla files from the HS3 library after I deleted the plugin from the plugin list, it seems they where still in the library after that.
Originally posted by Stones View PostThanks Steve. I am in europe so I will be heading for my bed. I will check in tomorrow and see what you came up with. I check my Tesla app and it updated fine, I went to the car and all setting was according to your User Guide. Turned on the car to see if that would push an update to your plugin, no luck. Just for your info. Have a good evening.
The program is up and running, so I can do the log file from your plugin page...prefer that ?
Thanks for fast reply Steve.... I am on it, did it once, wanted to upload the log file, but it is not allowed to upload a log file in the forum...why...jeeezzz
Originally posted by Stones View PostSorry to say Steve, it does not work on my system. downloaded and installed the new version. It does not update the Tesla that leads me to the Vehicle Config page
