Greetings. I'll be installing the PI when I get my X, hopefully by mid April. Is anyone using the plugin with an X and are there any differences between the 3 and the X that I'll see?
There are things that the X and S have that the 3 doesn't (and possible vice versa), but I've coded the plugin as best I can to match the API spec and use the information in the data to know what each car can/can't do. Things like sunroof control, heated steering, etc. are technically implemented, but totally untested All I can do is fix anything that shows up as a bug reported here as quickly as I can - unless a TON of people with Teslas buy HomeSeer and my plugin so I can get my wife an X, too!
