No connection after initial setup
  • No connection after initial setup
    After initial setup and choosing child devices, the PI won't connect and update any child devices. Also the Tesla Vehicle tab under the root device and Configuration for the vehicle is stuck with "Please wait for vehicle to update before configuring this vehicle.".
    Tried removing the PI and reinstalling with same problem. I can reach the car by the mobile app.
    Last edited by shill; June 4th, 2019, 05:42 PM. Reason: Downloaded log and removed from post. Thanks for providing that!
    Found the issue - I wasn't properly handling Celsius temperatures that were doubles, not integers... Submitted to HST, probably in the updater on Monday.
      Great, it's working now!
      Found another bug. When I click on location and the coordinates open in google maps. Coordinates must be with dot, not comma says google.
      Also when I try to add location, no map appears, so can't add.
        On quick glance, my location click works just fine here in the US, so perhaps that's a localization issue I need to research... could you go to google maps (using maps.google.com) and pick a public location in Norway and share the URL? For reference, here's a location in Raleigh that works just fine (that's the URL from my current location with the coordinates changed to a generic location, but otherwise the format and structure is identical):
        https://www.google.com/maps/search/?...77,-78.6465797
        The map not appearing is an issue I see clearly now - it only occurs when you're accessing HomeSeer via HTTPS, apparently. I'll get a new update pushed out for that as soon as I get home, so hopefully it will be in the updater tomorrow.
          I found in the google maps help page (in Norwegian) that you must use dot and not comma for coordinates, guess that's a global way. This link works fine, also the link you shared: https://www.google.com/maps/search/59.916333,10.7235603
          I google translated the topic for help coordinates: "Use dot as decimal point, not comma. Error: 41,40338, 2,17403. Correct: 41.40338, 2.17403."
            I'm still a bit confused because the URL I shared is correct, and that's what the plugin is generating... Can you post an anonymized version (change some numbers, but nothing else) of the exact URL the plugin is generating for you that isn't working properly?
              I copied the URL from the device: https://www.google.com/maps/search/?...9453,11,320288
              If I change the two commas with dots it works.
              The map for generating location still not working. I tried connecting local and by using my phone as modem over MYHS.
                Ah... is Tesla reporting your lat/long with the commas? I just use that value directly...
                  Looks like something went wrong with my uploaded package and it's not the right build. I'll fix the commas and this tonight and submit another update... sorry!
