V1.3.1.1 Configuration of the plugin = Arithmetic operation resulted in an overflow.
Originally posted by shill View Post
Understood, but those questions were part of my troubleshooting thought process and are still important. Also, please see the "having trouble? Follow the steps first" thread for more.
If you can't get to that screen because of a problem with startup or the config page itself, you can always disable the plugin, open the plugin's INI file (in the Config subdirectory) and set the value of LogLevelFile to 6, then start the plugin back up.
HS Version: 3.0.0.548
Plugin Version: 1.3.1.1
Description of problem: Configuration of the plugin = Arithmetic operation resulted in an overflow.
HS3 Server OS: Windows Server 2016 Standard
Lyric device & model?
Log file: attached
Data dump: I am unable to get to the tesla vehicles tab.Attached Files
Originally posted by shill View PostDid you just upgrade to 1.3.1.1, or is this a new install?
Do you remember what version you were on before? For some reason it didn't perform the upgrade logic it should have to update your vehicle ID to the other variable I had to switch to, so it's still trying to use the old one.- The ID your HS device thinks it should be: 6280530474636822
- The new ID assigned to your vehicle that would have replaced that: 1013271156290037
- The actual permanent ID it should have updated to use instead: 1614103930
One thing you could try to do, though I'm not sure I allow this (I need to in the future): go to the root device's device configuration page and on the Tesla tab, change the vehicle ID to 1614103930. I'm not 100% sure if that will correctly change the config section or not, but you could check it out.
If that doesn't work, you'd have 2 other choices:- Give me a few days to finish the next release, to which I will try to add some logic to fix your situation, which will mean none of your events will be broken.
- Stop the plugin, delete the devices created by the plugin, and update the config file to blank out the parent ref variable and the vehicle specific config section, which will allow you to add the car again from scratch, but will break all your existing events that reference those devices.
Originally posted by shill View PostOne thing you could try to do, though I'm not sure I allow this (I need to in the future): go to the root device's device configuration page and on the Tesla tab, change the vehicle ID to 1614103930. I'm not 100% sure if that will correctly change the config section or not, but you could check it out.
