Passenger temp
    Passenger temp
    On TMS/X there are separate settings for Climate Temp Passenger and Climate Temp Driver. I can only see the temp for the Driver. Changing this will not change the temp in the Tesla App.
    They changed the API so that it no longer allowed me to address the passenger climate setting. Can you change the passenger temp from your mobile app?
      No. But since you specify Driver Temp, I thought it was a setting for passengers as well. Perhaps rename it?
      Next: When I try to change the Driver Temp, it is not reflected in the Mobile app. Car set manually to 23 will still be 23 after sending Set To 24.
        Ah, fair point. Originally they app supported both, so the API supported both. They changed the app/API so I dropped the "Passenger Temp" device that used to be included and didn't think about renaming that device.
