Screenshots
This topic is closed.
This is a sticky topic.
  • Screenshots
    Some screenshots of the Worx Landroid plugin. See “Installation and Configuration” for screenshots during setup.
    Main devices, that holds the current status, errors and actions:
    Click image for larger version  Name:	worx11.png Views:	1 Size:	103.6 KB ID:	1373499
    You can start, stop and pause your robot here. Also, the Rain Delay can be set. The status updates automatically every 10 minutes, or more frequent when the robot is working and has a new status to report. You can refresh the data manually by pressing "Refresh", but normally that should not be necessary. Some fields require a little explanation:
    • Status: Unknown, Idle, Home, Start sequence, Leaving home, Follow wire, Searching home, Searching wire, Mowing, Lifted, Trapped, Blade blocked, Debug, Remote control, Going Home, Zone training, Border cut, Searching zone or Pause
    • Error: should be "No error" or "Raining" (if Rain Delay > 0). Other errors are Unknown, Trapped, Lifted, Wire missing, Outside wire, Close door before mowing, Close door to go home, Blade motor blocked, Wheel motor blocked, Trapped timeout, Upside down, Battery low, Reverse wire, Charge error, Timeout finding home and Battery overtempt
    • Worktime & Worktime Blade: Actual worktime in days.hours:minutes format
    • Run: The Landroid has 10 Runs, and then restarts from Run 1. If you enable zones (see below), you can configure a Zone for each run.
    • Zone: The current or next Zone that will be selected based on the Run number and zone configuration
    • Battery Status: Charged, Charging or Error.
    Zones configuration, only available when enabled in the plugin configuration:
    Click image for larger version  Name:	worx12.png Views:	1 Size:	119.0 KB ID:	1373500
    • Status: Normally all features will update automatically, unless a setting (any of the zone features) has been changed. Status will be set to "Pending changes" until "Refresh/Cancel" or "Saved" is selected.
      • "Refresh/Cancel" refreshes the current config and discard any pending changes.
      • "Save" will save the zone settings into the Landroid. Status will return to "No status".
    • Run 1-10: Tells the robot in which zone to start for each run.
    • Zone 1 - 4:
      • "Start" will attempt to start directly in this zone. It works by temporarily changing the zone configuration, which should be transparent for you and the zone configuration will be restored after the robot has started.
      • "Meter" is the amount of meters of wire the Robot will travel to decide in which zone the Robot is.
    Scheduler configuration, only available when enabled in the plugin configuration:
    Click image for larger version  Name:	worx13.png Views:	1 Size:	186.1 KB ID:	1373501
    • Status: Normally all features will update automatically, unless a setting (any of the schedule features) has been changed. Status will be set to "Pending changes" until "Refresh/Cancel" or "Saved" is selected.
      • "Save" will save the schedule settings into the Landroid. Status will return to "No status".
    • <Day> Start: Time to start
    • <Day> End: Time to stop. If this time is earlier than the start time, the next day is assumed.
    • <Day> Edge: Include edge mowing for that day
    • Scheduler Type: Automatic or Manual. It seems that "Automatic" overrules your schedule and behaves like you just unpacked your Landroid (there is a default schedule in the Landroid). If you want to set the Start and End times yourself, set it to Manual. If you like to disable the scheduler completely, set all start- and end-times to 00:00.
    • Time Extend: Add or subtract % of time to the scheduler without changing all individual timers.
    stefxx
