Remootio 3 ?
    Remootio 3 ?
    Does this work with the latest Remootio 3?
    https://www.remootio.com/blogs/tutor...and-remootio-2
    They don't appear to have functional differences AFIK.
    Although, the API may be different: https://github.com/remootio/remootio...ecification.md
    There's no difference, except added Bluetooth and mDNS discovery. I haven't tested, but if there are any issues - I will fix them.
      I am getting about a six+ second delay between the plugin reporting the open-closed status of the sensor. Is that normal? It's not earth-shattering, just curious.
        It's not under my control - Remootio uses WebSocket for comms - so responce should be immidiate.
        I will check with the Remootio creater.
        Can you verify just in case CPU usage of HS and the plugin, may be RAM as well. I suggest using Resmon.exe (not the Task Manager) - because even if Task Manager shows Available memory 9.9 Gb - the real Free memory is only 365 Mb - which slows computer down:
