Errors about every day or so
This topic is closed.
    Any thoughts?
    1/27/2022 6:02:27 AM
    Legacy-Plugin
    AK Remootio ERROR
    [3744]: Sending {"type":"PING"} - but websocket is 'Closed', trying to open
    1/24/2022 3:21:47 PM
    Legacy-Plugin
    AK Remootio ERROR
    1/24/2022 2:54:51 PM
    Legacy-Plugin
    AK Remootio ERROR
    1/24/2022 1:57:48 PM
    Legacy-Plugin
    AK Remootio ERROR
    [3744]: Device Restarted
    Date/time=1/27/2022 1:56:40 PM EST
    Version=HS4 Standard Edition 4.2.7.0 (Linux)
    MONO Version=6.12.0.122
    License=Registered
    Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
    Uptime=3 Days 18 Hours 55 Minutes 30 Seconds
    Lan IP=192.168.1.xxx (lenovo-homeseer)
    Device Count=957
    Event Count=229
    Plugins Enabled=drhsIpPlugIn:,IR Plugin:,BLLED:,UltraTivo3:,EasyTrigger:,BLBackup:,Z-Wave:,SDJ-Health:,Pushover 3P:,SonyTV:,AK Remootio:,NetCam Plugin:,rnbWeather:,Device History:,AK Weather:,UPBSpud:
    Modules/Threads=130 Modules, 106 Threads
    Available Threads=399
    HomeSeer Memory Used=286 Mbytes
    Plugins Installed=AK Remootio 3.0.0.5,AK Weather 4.0.2.15,Big5HS4 3.7.0.0,BLBackup 2.0.63.0,BLLED 2.0.1.0,BLOccupied 2.0.28.0,BLRussound 2.1.34.0,Device History 3.3.1.0,drhsIpPlugIn 0.0.0.31,EasyTrigger 3.0.0.75,IR Plugin 4.0.0.6,mcsMQTT 5.21.7.2,NetCam Plugin 1.0.0.6,OMNI 3.0.2.23,Pushover 4.0.5.0,Pushover 3P 0.0.0.52,RaspberryIO 3.0.0.19,rnbWeather 4.2.0.2,SDJ-Health 3.1.0.9,SonyTV 3.0.0.6,SurveillanceStation 1.1.1.0,UltraTivo3 3.0.7956.26531,UPBSpud 3.0.0.54,weatherXML 3.0.1.19,Z-Wave 3.0.9.0
    It must be fine, connection should be restored, but I'll check
      I'm still getting errors:
      [COLOR=#c0392b]3/12/2022 11:57:59 AM
      Legacy-Plugin
      AK Remootio
      [3744]: Device: Garage Door - Double Set to 6
      Legacy-Plugin
      AK Remootio
      [3744]: Device: Garage Door - Double Set to 5
      Legacy-Plugin
      AK Remootio ERROR
      Legacy-Plugin
      AK Remootio
      Legacy-Plugin
      AK Remootio Warning
      [3744]: WebSocket Connected
      Legacy-Plugin
      AK Remootio ERROR
      3/12/2022 11:57:44 AM
      Legacy-Plugin
      AK Remootio
      [3744]: Device: Garage Door - Double Set to -1
      Legacy-Plugin
      AK Remootio Warning
      [3744]: WebSocket Closed code: 1006, reason 'An exception has occurred while receiving.' [/COLOR]
        But as I said, it should re-connect when connection is lost. Does it keep working?
          There is concern that the door might get stuck up or down when there is no connection. This device is arguably more important than a lock on door. Unlike a locked or unlocked door this device opens the door wide. I invested in the Remootio because of your plugin. I'm nervous about relying on it with these connection issues since they are repetitive.
            The whole idea of sending "PING" is to verify that connection is still active.
            I made some changes, try ver 3.0.0.6 (BETA).
            But I'll do more testing tomorrow (it's past 1 AM here in AU), will try to kill the WebSocket manually.
            In the meantime you might enable Log, or even Comms Log and post more logging to what's happening.
              Thanks, I'll try ver 3.0.0.6 when it appears. I read on the forum there may be a problem with updates for plugins showing up. The highest version of AKRemootio is still at ver 3.0.0.5
                  Yes, I know about that button. And I'm still showing 3.0.0.5 as the current Beta.
                    I had to toggle OFF/ON the Beta Plugin switch to get it to display 3.0.0.6. Clearing the browser cache and reloading didn't work.
                      I'll port the plugin to HS4. I don't want to waste time on old version.
                        That's great news! I'll look for it.
                          Feel free to hassle me within few days, I may forget
                              Is it a few days yet?
