Anybody knows a way to prevent damage to IT100? It's seams that when there a storm nearby my it100 gets damaged, anyone seem this in your setup?
IT-100 damaged with storm
Originally posted by jono View PostI used to get a lot of DSC IT-100 boards damaged by nearby lightning. Somewhere I read a tip to make sure my DSC system had a really good ground on the main DSC board. Since I wired that in, I have not seen a blown board. It may be a coincidence, but it is easy enough to try.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Originally posted by Rotech View PostWhere on the board did you ground it? And what source of ground did you ground it too?
Hope that helps.Last edited by jono; July 5, 2018, 07:23 AM.
Originally posted by jono View PostOn the DSC 1864 main board there is a ground connection (labelled EGND) 5 slots from the end. I connected that directly to the ground wires feeding my wall plug. I also use an plug in surge detector for the plug that the alarm system gets its power.
Hope that helps.Hector
Win.2003 OS, HS3
