Blade, didn't see it in the Help, but is there a script method to bypass a single zone? Also, would it be possible to add a 'Toggle Bypass' control on each one, similar to the HST DSC plugin?
Zone Bypass script method?
You can always use the virtual keypress in events or scripts to bypass zones.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
Do you have an example of the command? When I run the following, I get an error.
Dec-19 9:59:00 AM Error Running script(2) &hs.PluginFunction("BLDSC", "", "VirtualKeypress", New Object(){"*1"}), init error: Expected end of statement
Dec-19 9:59:00 AM Event Running script statement immediately: &hs.PluginFunction("BLDSC", "", "VirtualKeypress", New Object(){"*1"})
