I am trialing the BLDSC plugin because I've hit some issues with the homeseer DSC plugin and have not received any replies in that subforum. Specifically, it's a "too many files open" error that crashes the Zee on a daily basis.
Anyway... I installed the BLDSC plugin and disabled the Homeseer plugin. In the setup, I added 1 partition and told the plugin that I have 8 zones. I also set the com port as "0". The homeseer plugin successfully communicated with my DSC 1832 on port "/dev/ttyUSB0".
The log shows the following every few minutes:
Sep-12 2:43:18 PM BLDSC start BLDSC plugin has been initialized
Sep-12 2:43:18 PM BLDSC start Users have been loaded
Sep-12 2:43:18 PM BLDSC start Zones have been loaded
Sep-12 2:43:18 PM BLDSC start Partitions have been loaded
Sep-12 2:43:18 PM BLDSC start Loaded configuration successfully
Sep-12 2:43:17 PM BLDSC start BLDSC version is: 2.0.46.0
Sep-12 2:43:17 PM BLDSC start Initializing BLDSC...
Sep-12 2:43:17 PM Info Plugin BLDSC has connected. IP:127.0.0.1:59033
Sep-12 2:43:15 PM Warning I/O interface BLDSC is down, executable is not running, restarting ...
Sep-12 2:43:06 PM Info Plugin BLDSC with instance: has disconnected
So it looks like it's successfully connecting, and then becomes disconnected within about 10 minutes. I'm not seeing any device or status updates. If I go into the BLDSC's settings and choose the Real-time Log button, the page freezes and eventually times out without showing any log info.
Any help is appreciated!
