JSON Error missing interface
    Hi all,
    Trying to use BLLock to add user PINs. Instead, in the log, I'm getting this:
    theResponse --> { "Response":"Error, missing interface" }
    Here's the full section of the detailed log -- and I do have a non-standard port for HS3:
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): port --> 81
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): fullLanIp --> 192.168.0.84 (KCX-HS)
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): splitArray.Length --> 2
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): lanIpAddress --> 192.168.0.84
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): url --> http://192.168.0.84:81/JSON
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: request; value: pluginfunction
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: plugin; value: Z-Wave
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: function; value: AddUserCodePin
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p1; value:
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p2; value: 5
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p3; value: 1111
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p4; value: Test user
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parm: p5; value:
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): parameters set
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request(): theResponse -->
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Send_Homeseer_JSON_Request() finished
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Request_Add_User_Code_Pin(): theResponse --> { "Response":"Error, missing interface" }
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Request_Add_User_Code_Pin(): theJsonResponse.ToString -->
    JSONResponseZWaveAddUserCodePin:
       Response: Error, missing interface
    03/17/2018 01:43:41:922 PM : v3.0.11.0 - Request_Add_User_Code_Pin() finished
    Does anyone know what "Error, missing interface" means? I do have JSON enabled and when I do test posts to /JSON, I do get responses.
    HS3 3.0.0.423
    ZWave: 3.0.1.206
    Thanks!
    The plugin did not get your zwave interface id
    Do this:
    1. Disable plugin
    2. Edit hspi_BLLock.ini and change debugLevel=true
    3. Save ini file
    4. Re-enable plugin
    Wait until your locks are found and then stop debug logging
    Attach the BLLock-Detailed.log zipped
    It is in the HS3 root folder
    Cheers,
    Bob
      Blade - just to close the loop on this (and apologize for not getting back with you to troubleshoot this issue; life has been crazy) - it works! I updated to the latest available build (3.0.13.0) and I was able to convert the locks to BLLock.
      A couple of issues I had:
      1. On one lock, the HS3 log showed that all users were converted. When I went to view the lock in BLLock, only 1 user entry was shown! I re-entered the users for that lock in BLLock. I seem to remember reading that others had this issue too, but it seems fixed now.
      2. When I add users to the lock, I don't see log entries in the HS3 log showing that they were programmed. This may be by design. I am remote, so I haven't been able to test yet to see if they were actually added.
      Thank you!
      hjk
        I am sure this can be added
        I will have a look
        Cheers,
        Bob
          Try out 3.0.14 in the beta section
          I added HS3 log messages for adding and removing lock codes
          Cheers,
          Bob
            Blade - at first, I still didn't see any log entries. Then I tried a different lock, and I saw the messages. THEN, I noticed the difference.
            I have 3 locks, but one of them is mis-identified:
            • Garage door lock - BE369
            • Back door lock - BE469NXCAM716
            • Front door lock - BE369 <- misidentified; this is a BE469NXCAM716
            When I go to Users on the Back Door BE469NXCAM716 (and, for that matter, when I go to Users on the Garage Door BE369), I have the option to add a user or delete a user.
            When I go to Users on the Front door lock, the BE469 which is mis-identified as a BE369, I have an "Edit" button which lets me disable or enable users. This doesn't seem to have any effect, nor any HS3 log entries, when I delete/add/disable/enable users.
            When I look at the HS3 log when I did the conversion yesterday, I do see that all 3 locks were converted.
            So... I don't know if something strange is marked on this Front Door Lock, or if it is because it is mis-identified, or what... but something is different about it.
              It is like the lock with the user edit button has not been converted
              Can you attach your hspi_BLLock.xml file zipped
              Cheers,
              Bob
                Sure -- can I PM this to you, or maybe email it?
                  Go ahead and email it to me
                  Also run the script in this thread and send me the output log
                  https://forums.homeseer.com/showthread.php?t=161081
                  Cheers,
                  Bob
                    Blade -- I think I fixed it. There was weirdness in the INI, probably due to multiple versions of BLLock over the years. That lock was defined 3 or 4 times with codes (encrypted) listed and different ID numbers.
                    I stopped BLLock, manually edited the INI, and removed all references to the lock. When I re-started BLLock, it found the lock and got the existing codes.
                    Since I've had a few codes which dropped off the lock itself, I went ahead and deleted all door codes and added them back using BLLock. They added successfully and I just tested, and they worked.
                    Thanks for your help!
                      Glad you got it sorted out
                      Cheers,
                      Bob
