I just upgraded to the latest version of HS3 and BLLock. I have 5 Schlage FE599 levers and 3 BE369 deadbolts across two houses/installations and thought I'd check a an issue I noticed in the past and it's still there:
In the plug if I push the "unlock" button when the lock is in a locked state, the lock is unlocked (however the page does not refresh and show the new status).
After I refresh the page in the browser, the status correctly shows the lock as unlocked, and I hit the "Lock" button to lock it again, but BLLock sends the unlock command instead of locking it => you can't lock the locks from the plugin. See the log file below with the entries after hitting "Unlock" and "Lock" in sequence.
Jan-18 8:37:32 AM Device Control Device: Security Door Locks Kitchen Lever to Unlock (0) by/from: CAPI Control Handler
Jan-18 8:37:08 AM Device Control Device: Security Door Locks Kitchen Lever to Unlock (0) by/from: CAPI Control Handler
I'd probably say this is a pretty critical functionality issue. Also, it'd be nice if the page refreshed and showed the updated status after the buttons are used, or if the lock status changes from another event.
