2019 - BLRing PI 2.0.29.0 (Beta)
    Bob,
    I see that you've released a new update of BL Ring... Firstly many thanxs! I've installed Ver 29.0 and it seems to be working I'm in the process of developing some Events to work with them will advise if any issues should arise, Mike
    Computer: CUK Intel NUC7i7BNH
    Op System: Windows10 Pro - Work Station
    HS Version: HS4 Pro Edition 4.2.19.0
    Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
    Well wrote my first Ring Event, there seems to be significant delay (3-5 minutes) from the time depressing the door bell and detecting/announcing within BLRing PI Is this because the PI is reacting from a discrete sent from the Ring Website? I've notice when I use the IOS Ring app that it takes multiple minutes after either a motion or door bell actions to appear on the app, whereas the Chimes report are instantaneous? Mike
      One of our ring devices shows offline in HS3 even though the return information from ring in the debug file shows it is online.
      Doorbot:
         id: *** REMOVED ***
         description: Backyard
         device_id *** REMOVED ***
         time_zone: America/Chicago
         subscribed: True
         subscribed_motions: True
         battery_life: 100
         external_connection: False
         firmware_version: Up to Date
         kind: hp_cam_v2
         latitude: *** REMOVED ***
         longitude: *** REMOVED ***
         address: *** REMOVED ***
         owned: True
         motion_snooze:
         Settings:
            enable_vod: True
            exposure_control:
            motion_snooze_preset_profile low
            motion_snooze_presets none,low,medium,high
            live_view_preset_profile: highest
            live_view_presets low,middle,high,highest
            pir_sensitivity_1:
            vod_suspended:
            doorbell_volume: 11
            vod_status:
         Features:
            motions_enabled: True
            show_recordings: True
            show_vod_settings
         Alerts:
            connection: online
         Owner:
        My backyard Cam also shows offline in this PI.
          I will check into the doorbot showing offline
          Cheers,
          Bob
            Hey Blade were you able to see the doorbot (backyard cam) offline issue and any idea for a fix? Thanks
              I just looked at the code and nothing it jumping out at me
              Can you turn on debug logging and capture the doorbot data coming into the plugin
              Leave it on for a couple minutes and then disable debug logging
              Email me the debug log zipped
              It is in the HS3 root folder
              blade9123 at gmail dot com
              Cheers,
              Bob
                Done.
                  Hi Bob,
                  Firstly, my thanks to you for all your sterling work and contributions to the Homeseer community - I'm sure I echo hoards in my appreciation!
                  Secondly, please excuse this newbie for any gross oversights in this my first forum post.
                  Very keen to get this plugin up and running on my setup - I installed the current 2.0.27.0 version which I read is known to be presently inoperative, had high hopes in finding this thread that I could grab a functional version, albeit beta.
                  Unfortunately I cannot find (any version of) BL Ring in the Beta section in the Homeseer Updater?
                  Feel like I'm missing something!
                  Please could you help me join the dots on where I may be able to pick version 2.0.29.0 up from?
                  Many thanks,
                  Faber.
                    BLRing is under Security in the updater
                    Cheers,
                    Bob
                      Hi Bob,
                      I installed the version available under Security in the updater, but this just gives me the defunct V2.0.27, not the v2.0.29 as is being discussed in this thread.
                      It is this latter version that I can't seem to find anywhere?
                        I just updated to 2.0.31...check under beta plugins.
                          Hmmm it appears the beta is gone - I will add it when I get home
                          Cheers,
                          Bob
                            Many thanks Bob - thought I was going mad there!
                              Can you check the beta section now
                              Cheers,
                              Bob
