I couldn't get this plugin to work yesterday when I loaded it, but I was able to setup a workaround using Alexa routines. I created 2 virtual devices "Ring Doorbell" and "Ring Motion", checked "IsLight" in settings and checked "voice command". I ran the Alexa device discovery and created 2 routines, 1 for motion, 1 for doorbell. Under the routines I set Alexa to turn on the corresponding virtual device in each routine.
That allows Homeseer to have a device change when motion occurs or when the doorbell is pressed. That was all I was looking for. If you use this route, be sure and reset the devices to "Off" after you use them as a trigger, or after some timeout.
