Error Disarming from Event
    Trial version
    In testing disarming from an event using the BLSECURITY Disarm action, I hung things up.
    The event took a long time (2 mins) to complete. Normally it just sends an email and plays a couple of messages when I press an X10 button in the morning. I added the Disarm and things went way south.
    I tried to disable the plugin and re-enable it. That didn't work. Shutting down HS3 and restarting, BLSECURITY did initialize successfully.
    Regards
    Michael
    Jan-26 7:10:40 AM Error Initializing plug-in(2): BLSecurity Instance::Object reference not set to an instance of an object.0STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    Jan-26 7:10:40 AM BLSecurity start BLSecurity plugin has been initialized
    Jan-26 7:10:35 AM Plug-In Finished initializing plug-in BLSecurity
    Jan-26 7:09:40 AM NO ECHO No Echo for MBR Motion Sensor, Echo (10 secs)
    Jan-26 7:09:38 AM BLSecurity start Devices have been loaded.
    Jan-26 7:09:36 AM BLSecurity start Loaded configuration successfully
    Jan-26 7:09:36 AM BLSecurity start BLSecurity version is: 2.0.4.0
    Jan-26 7:09:36 AM BLSecurity start Initializing BLSecurity...
    Jan-26 7:09:35 AM Info Plug-in BLSecurity has connected successfully
    Jan-26 7:09:35 AM Info Remote application or plugin has connected: 127.0.0.1:3965
    Jan-26 7:09:35 AM Info Remote application or plugin has connected: 127.0.0.1:3964
    Jan-26 7:09:35 AM Plug-In Interface BLSecurity is running as a trial, 22 days remaining.
    Jan-26 7:09:30 AM ECHO Echo for MBR Motion Sensor, No Echo (33 secs)
    Jan-26 7:09:29 AM Motion ***Master Bed Room***
    Jan-26 7:08:54 AM Info Plugin BLSecurity with instance: has disconnected
    Jan-26 7:08:54 AM Plug-In Shutting down Plug-In: BLSecurity
    Jan-26 7:08:54 AM Error Calling HSEvent in plugin BLSecurity, Instance :Object reference not set to an instance of an object.
    Jan-26 7:08:08 AM Warning Plugin BLSecurity is not responding but it is still running, not restarting yet.
    Jan-26 7:07:20 AM Error Getting plugin in PagePut: Object reference not set to an instance of an object.
    Jan-26 7:06:55 AM Device Control Device: 2nd Floor LR Porch Light to Off (0)
    Jan-26 7:06:55 AM Device Control Device: 1st Floor Pool Porch Lights to Off (0)
    Jan-26 7:06:55 AM Device Control Device: 1st Floor Kitchen Porch Light to Off (0)
    Jan-26 7:06:55 AM Event Event Trigger "Time Triggered Sunrise"
    Jan-26 7:06:54 AM Error Calling HSEvent in plugin BLSecurity, Instance :Object reference not set to an instance of an object.
    Jan-26 7:06:20 AM Error Getting plugin in PagePut: Object reference not set to an instance of an object.
    Jan-26 7:05:38 AM Warning Plugin BLSecurity is not responding but it is still running, not restarting yet.
    Jan-26 7:05:20 AM Error Getting plugin in PagePut: Object reference not set to an instance of an object.
    Jan-26 7:04:54 AM Error Calling HSEvent in plugin BLSecurity, Instance :Object reference not set to an instance of an object.
    Jan-26 7:04:20 AM Error Getting plugin in PagePut: Object reference not set to an instance of an object.
    Jan-26 7:03:20 AM Error Getting plugin in PagePut: Object reference not set to an instance of an object.
    Jan-26 7:03:08 AM Warning Plugin BLSecurity is not responding but it is still running, not restarting yet.
    Jan-26 7:02:54 AM Error Calling HSEvent in plugin BLSecurity, Instance :Object reference not set to an instance of an object.
    Jan-26 7:02:53 AM Event Deleting event after run: "Delayed Actions D3 (Delayed Action)"
    Jan-26 7:02:53 AM Device Control Device: Remote Keypad D3 to Off (0)
    Jan-26 7:02:53 AM Event Event Trigger "Delayed Actions D3 (Delayed Action)"
    Jan-26 7:02:53 AM Error Event Device Status Change Send Ping Email plugin action failed:Object reference not set to an instance of an object.
    Jan-26 7:00:57 AM email Email successfully sent to xxxxxxx
    Jan-26 7:00:53 AM TTS Speak (*:*):You have used 0 gallons of water today.
    Jan-26 7:00:53 AM TTS Speak (*:*):Your message has been sent
    Jan-26 7:00:53 AM Event Event Trigger "Device Status Change Send Ping Email"
    Michael
    HS3, W10 Home, HSTouch, W800, Z-Stick+
