Panel in HSTouch - Working!
  • Guest's Avatar
    Guest replied
    I am interested in this as well. It looks like BLSecurity has support for a script to trigger arm/disarm/etc events, but it doesn't look like there is any way to send the passcode with the disarm. It looks like HSTouch supports sending the pin as a variable if I store it in a passcode textbox.
    Has anyone had any success with sending the passcode to the plugin from HSTouch when the disarm/arm/perimeter button is set?
  • mmn
    I don't think I can help you with what you want to do, I can only describe what I did and am doing. But there are some real wizards here that can work magic with HSTouch.
    However, I can say that it should be fairly easy to determine and display what device(s) are in Alert and preventing arming. Could be wrong though. Happens more often than I can believe!
    Good luck!
  • Vincenttor
    that sounds great,
    i do got it working a bit that it showed what the state was from arming etc in just a text box.
    But what i do not get working correct or displayed is when a sensor is on armed mode it does not show that it has to be closed first.
    The keypad would be great if it could be done as i am planning to use different codes to enter for the users.
    Would also not be wise to have a arm/disarm button on the wall of the tablet, if a burgler comes in and pressed disarm and no code is needed
    you can make it work by adding a button and then instead of the button tekst you add
    http://yourserverip: port/blsec?page=blsecpanel
    Then you do get the screen what you normally get in the webbrowser but this is not a great solution.
    especially on a mobile device i have noticed
  • mmn
    I just used Blade's panel gif as a background and overlaid some transparent buttons. I only implemented the arm/diarm functions and not the security code (yet). I added a couple of things like last alert device and time, date/time of day, and some weather info.
  • Vincenttor
    Hi Michael,
    did you used the way to let a html code show up.
    Or did you used the image and set the correct value's etc to the keys and lcd screen readout ?
  • mmn
    Actually that was ridiculously easy to do! Haven't done the whole thing but the ARM DISARM buttons work.
    Regards
    Michael
  • mmn
    started a topic Panel in HSTouch - Working!
    I would like to implement something like the Security Panel in BLSecurity in HSTouch. Anyone know of any templates available to use as a basis?
    Regards
    Michael
