Turning BLSecurity Into a Z-Wave Alarm System?
    #16
    Try 2.0.21 and let me know
    Cheers,
    Bob
      #17
      The Room and Floor are present but not the device name
      RJ_Make On YouTube
        #18
        It's the same for the edit screen too.
        RJ_Make On YouTube
          #19
          Should there not be a "Z-Wave" type also.. As you see I've picket the DS10A, but.....
          RJ_Make On YouTube
            #20
            I am confused as to what is missing in the device name
            It looks like the floor got added to what was there before
            Please clarify
            Cheers,
            Bob
              #21
              You are correct, I didn't see the space on the edit window, and I guess I got confused (eyes playing tricks on me I guess)
              No space between the Room and Floor on the edit page..
              RJ_Make On YouTube
                #22
                2.0.22 should fix space issue
                Cheers,
                Bob
                  #23
                  Thank You Sir!
                  RJ_Make On YouTube
                    #24
                    No problem
                    Cheers,
                    Bob
                      #25
                      Looks like I found some other area's.. The Alarm Panel, and in the HS Last Aleart Device.
                      RJ_Make On YouTube
                        #26
                        Try 2.0.23
                        Cheers,
                        Bob
                          #27
                          I'm having 2 problems...
                          The first is the TTS system is not using floor or room.
                          Speak ():Arming Security System , , Attention , , the following security devices are in alert status., , Z-Wave_Door Door_Sens, , Z-Wave_Door Door_Sens, , Z-Wave_Door Door_Sens, , please close all doors and windows to continue arming sequence or execute the arming action again to temporarily ignore the devices.
                          The Second; for some reason the system will not arm, continues to say the door sensors are open, when in fact they are not. I'm sure I'm missing something, but I've tried different On/Off value with no success.
                          RJ_Make On YouTube
                            #28
                            any thoughts on this Blade?
                            RJ_Make On YouTube
                              #29
                              Try 2.0.24
                              Cheers,
                              Bob
                                #30
                                Worked perfectly.. Thanks!
                                RJ_Make On YouTube
