Is Plugin Still Supported or on the way to being discontinued?
    #16
    For last device alert:
    Please refer to this post for pics:
    http://board.homeseer.com/showpost.p...92&postcount=2
    Here it is without the pics.
    BLSecurity > Go to Options. Under Options you'll see Alert Options.
    Under Alert Options you'll see More Alert Options (click that).
    Now put the emails you want to be notified when there is an alert.
    An Important Note:
    When in arm mode(or any other) and devices are NOT part of a ZONE, then you will get emails for every devices that gets triggered.
    The email Subject line will say( for armed mode): "Security Alert (Mode: Armed)"
    The Body of the email will say "At 1/19/2016 8:06PM, an alert was triggered by Device: Motion Hallway Motion Sensor"
    Zones:
    Now if the device is part of a ZONE, and if this device was triggered, then body of the email will say " At 1/19/2016 8:10 PM, an alert was triggered by Zone: Inside House". So if device is part of a Zone, the device that triggered the alert will not get listed, only the Zone info gets sent.
    UPDATE: Regarding Zone Email-
    So Blade will make it capable to so that when a Zone is triggered, the device that triggered will be listed on another line in the email.
    Tom
      #17
      I was reading more last night into the very very old threads of BLsecurity and found this script on how to announces which door is open to BLSecurity? I know I put a feature request for this, but until then maybe this would work?
      I'm dumb about scripting so pardon my dumb questions.
      1. I think this used by a user in HS2, will it be the same for HS3?
      2. How do I add this script to BLSecurity?
      Imports System.Threading
       Sub Main(parms As Object)
       Dim OfficeTestDevice = hs.DeviceStatus("\15")
       Dim BackDoor = hs.DeviceStatus("\6")
       Dim RFrontDoor = hs.DeviceStatus("\5")
       Dim MBPorchDoor = hs.DeviceStatus("\19")
       If OfficeTestDevice = "2" then
          hs.speak("{sound=Notify,queue=discard}" & " ", True, "*:Office,*:Livingroom,*:Upstairs")
          hs.speak("Warning, the Office Test Device has tripped!", true, "*:Office,*:Livingroom,*:Upstairs")
       elseif BackDoor = "2" then
          hs.speak("Warning, the back door has opened!", true, "*:Office,*:Livingroom,*:Upstairs")
       elseif RFrontDoor = "2" then
          hs.speak("Warning, the front door has opened!", true, "*:Office,*:Livingroom,*:Upstairs")
       elseif MBPorchDoor = "2" then
          hs.speak("Warning, the bedroom porch door has opened!", true, "*:Office,*:Livingroom,*:Upstairs")
       End if
       Thread.Sleep(20000)     ' sleep 20 seconds
       hs.Plugin("BLSecurity").ResetAlertStatus()
       End Sub
      Tom
        #18
        Try this for HS3:
        Note: The speak commands are using BLSpeech tags
         Dim OfficeTestDevice As Boolean = hs.IsOn(hs.DeviceExistsCode("\15"))
         Dim BackDoor As Boolean = hs.IsOn(hs.DeviceExistsCode("\6"))
         Dim RFrontDoor As Boolean = hs.IsOn(hs.DeviceExistsCode("\5"))
         Dim MBPorchDoor As Boolean = hs.IsOn(hs.DeviceExistsCode("\19"))
         If OfficeTestDevice = True then
         elseif BackDoor = True then
         elseif RFrontDoor = True then
         elseif MBPorchDoor = True then
         End if
         hs.PluginFunction("BLSecurity", "", "ResetAlertStatus", Nothing)
        End Sub
        Cheers,
        Bob
          #19
          BLSpeech = learning curve for me I just watched a few minutes of the video and I need to study BLSpeech a bit more.
          Is there away to use the script without BLSpeech, but with only BLSecurity and regular HS speech?
          Sorry if this is ignorant question. Kind of all new to me.
          Tom
            #20
            You can take out the {} tags in the speak commands
            Cheers,
            Bob
              #21
              Ok thanks,
              So say for I have Door Sensors called OfficeTestDevice, BackDoor, RFrontDoor MBPorchDoor as in the script below.
              I create an event that says
              IF OfficeTestDevice Changes
              Or IF BackDoor Changes
              Or IF RFrontDoor Changes
              Or IF MBPorchDoor Changes
              Then run script
              I know I'm wasting your time with these not worthy of your intelligence and time questions (sorry), but I as soon as I figure this out I'll post back here with details so others who may be want this will have a guide if they need it. Thanks again.
              Tom
                #22
                Here is the script with no BLSpeech tags:
                 End if
                End Sub
                Cheers,
                Bob
