Vers 10
  • Vers 10
    Posted an update to Vers 10. I had a versioning issue where some had Ver 9 and others Vers 9a
    All functionality should now be in Vers 10, particularly Remote Arm. You'll see a new Button on the Control Panel for that use. Remote Arm just allows you to Arm the panel to away without having to open/close a perimeter door.
    Z
    Cheers Vasrc
      sorry as I'm slow to grasp things.. LOL..
      remote arm - have the button...
      but your saying if you click it and a door is open, it will still arm? if so does it do a bypass on that device?
        No.
        To arm away the panel usually needs to see you exit (ie door opens/door closes). If you don't, it goes to Arm Stay which disables some (depending on your config) devices. This just allows you to Arm Away remotely when you forget to arm it.
        Z
          Originally posted by vasrc View Post
          No.
          Z
          Thank you .. I will verify that later. I set my alarm earlier as away from web as my wife forgot. I didn't realize it sets to arm stay...
            Are you using HSTouch or the web Api. You should see the Armed Status displayed on the screen after you have armed it. It initially displayed Armed Away but after the beeps stopped and the exit sensor wasn't tripped it reverted to Armed Stay. That's now resolved with Remote Arm.
