HS4 and the Concord 4 plug-in
  • #16
    I tried setting up HS4 (Windows 10) this morning and ran out of time. Had to revert back to HS3. Got as far as the install, reset port but need to read more on getting HS3 setup into HS4. Also couldn't seem to find where to install license. It didn't prompt me for it? I would like to just copy stuff from HS3 > HS4 manually instead of a complete setup. -Matt
    2/24: Had a little more time to play with HS4 Pro on Windows 10.
    1. Shutdown HS3
    2. Backed up complete HomeSeer HS3 > HomeSeer HS3_Backup
    3. Uninstalled HS3 from Windows (didn't remove HS3 files when asked)
    3. Changed HomeSeer HS3 to HomeSeer
    4. Installed HS4 to HomeSeer
    5. Registered (http://yourHSip.../register.html
    *I had an issue getting HS3 license in. Had to double click my password, enter and then enter HS3 license?? Worked
    So far, looks OK but devices for Concord not displaying. The alarm is ACK so no annoying beeps.
    Edit: 2/24 Restore Concord Devices fixed
    1. Setup > Labs > Click Fix Device/Feature Relationships and restarted
    Edit: 2/25 Concord devices are showing up now as well as my other PI's. My first impressions from 20k feet > So far I see the GUI changed which I prefer the older version. Going into the devices (Concord at least) and the internal tabs aren't finished or working yet. Yup, beta. I'll see how the internals have changed. YMMV.
    Hope others have some tips, tricks as we move forward.
    Matt
    • #17
      mattm55 are you using HS Mobile. Have you experienced the lag in device update I mentioned above.
      • #18
        No. I haven't tested HS Mobile. Ill give it a try soon.
        Matt
        • #19
          no lag to report but i can say that when i go to add an event, only one device shows up. it isnt anything worthhile... has anyone else experienced it?
          i cant setup emails on panel control as i cant get to it... nor can i setup turn garage lights when door opens...
          i posted in hs4 beta area
          • #20
            anyone confirm?
