door window sensors
    door window sensors
    So these are what I have.. i have a possible defective one. i replaced the battery but it still is giving an error as im not home to give the error. but biggest thing is the plastic back broke where screws mount it so dont mind replacing with the same one...
    but what wireless door/window yous guys using?
    https://www.surveillance-video.com/s...-29-319-5.html
    What error?
    Sure it's not a tamper alarm? The Tamper switches on these corrode after so many years and they're a pain to get working again. I just jumper them out.
    Z
      Originally posted by vasrc View Post
      What error?
      Z
      thx.. i yanked powwr and battery. let it reset. powered on. set date and time. im in!!!!
        Yes, I had the same issue with the tamper. If it's the issue, it will come back. I bought a bunch of Interlogix NX-650's and just replace as needed.
          yeah it didnt say Tamper.. it said Supervisory and wouldnt go away. Still may buy one as the back where the screws hold it to the sliding glass is broken and barely held on at this point..
            Supervisory from my experience was a problem with bad caps after a battery replacement. Another reason I bought a bulk amount. I think you could tell by the color of the caps if I remember correctly. My experience with the sensors is good except for the occasional Tamper, Supervisory(battery low or changes) and 1 completely dead sensor. I even had a hardwired switch go bad a few months ago.
              yeah i gotta order one... this one went and tripped again. plus as i stated, the back is broken and its hard to mount now.
                so you have listed that you bought nx-650's... are the nx-656 just a newer model?
                  No. That looks like its a "glass" sensor and is different. The NX-650's (window frame mount) are around $15-$25 ea. I think I bought 20 from a fleaBay sale for something like $150. My NX-650's are backed up by motions so glass breakage isn't my worry. I also have 360 coverage of IP cams. YMMV
                    crap... bought them... oh well... LOL
