I know this should be simple,. When I was running my old vera lite using their concord 4 plugin, the setup I had was when I armed the concord 4 to either stay or away, I triggered a device (door lock) to set to lock. Using this plugin I cannot seem to figure out how to accomplish this. I have tried a number of different combinations but no go. Does anyone know how to accomplish this? Ie: Homeseer -- > set alarm panel to armed (stay or away) ---> trigger device door lock lock to lock. Another odd thing is I can select Concord users and the actions display armed stay and armed away, but whenever I try to set a function to armed stay, it reverts to armed away. ?? Thanks.
Need help setting up a simple event HS4 with concord 4 plugin.
Originally posted by mikeyR View PostAnother odd thing is I can select Concord users and the actions display armed stay and armed away, but whenever I try to set a function to armed stay, it reverts to armed away. ?? Thanks.
Are you using Delay or Silent?
Does the change from STAY -> AWAY occur immediately?
Are you exiting through any door after you've armed?
How/where are you seeing that it changed to AWAY?
What does the Concord Plugin Log say happened. Does it show STAY -> AWAY?
Z
