Creating events
  • Creating events
    Hey guys, I am trying to create an event that triggers when I arm or disarm my alarm. I have tried doing it by using the device status for the Panel Status changing to On and that did not work.
    How are you guys triggering events with this plugin?
    You're on HS3 or HS2?
    On HS3 you have two options:
    1. Select "Device Value is/Changed" and use Concord Control then Disarmed
    2. Concord User allows you to select a specific user to trigger off of
    Z
      Sorry, forgot about that. I am still HS2 for now.
      Planning to migrate in the next couple of months as they get closer to a true release, so your answer for HS3 will be valid!
        All is not lost
        Device Value Change -> Concord Plug-in Panel Control
        Z
          OK, so change my event from triggering on Device Status change to On to triggering on Device Value changed to Armed?
            Should work, give it a try.
            Z
