Log file creation
  • Log file creation
    Hi,
    Thanks for creating this plugin! I've just upgraded to HS3 and installed the plugin to see how it works. It has been working fine, but I was getting error messages in the HS3 console:
    11/30/2014 3:12:36 PM ~!~CONCORD~!~WriteLog() - Error Could not find a part of the path 'C:\Program Files (x86)\HomeSeer HS3\Logs\CONCORD\CONCORD_2014-11-30.log'.
    Apparently, the "Concord" directory wasn't created under HomeSeer HS3\Logs during install. Not sure what happened.
    Once I manually created the directory, the log files were created and the errors dissappeared.
    Hope this helps!
    Hi,
    Yes, depending on your OS (Win XP, 7, 8+...) you'll find that permissions to C:/Program Files might limit what is created. I would recommend creating a C:/HS3 dir and placing everything in there. You may find some other issues down the road running in the C:/Program.... dir with access, creation, etc...
    YMMV...
    Thanks, Matt
    Last edited by mattm55; December 1st, 2014, 07:22 AM. Reason: Dir Structure Example
