New version in updater?
  • New version in updater?
    I dont want to update what is working until I know what changed...
    so what changed???
    from 3.0.1.11
    to 3.1.13.1
    so what changed???
    from 3.0.1.11
    to 3.1.13.1
    Primarily cleanup. ALso fixed the Log issue you noted earlier. Was an issue with the Event trigger, which should be resolved now. Worst case, save the old EXE and you can revert easily.
    LMK if you find anything,
    Z
      Z
      ill test it tomorrow... but sounds good... thx!
        Hey guys,
        Once this is stable can you send over the source. I'll make this one the version we start with in GIT as well. I might put it into Google Developers Console for GIT.
        Thanks, Matt
          Linux?
          Hey Guys,
          I don't see this plugin in HS3 for linux. I am happy to test this out in that environment if the zip/git can be made available.
            Apologies if this shows up twice. New to the board.
            Guys,
            I am attempting to test this plug-in under HS3 and linux on pi2. But it isn't in the available plugins. How could I get access to help test this out in Linux? I am not a linux neophyte, so can help diagnose issues, assuming I can get the plugin to function with my concord 4 system.
            Ro
              Guys,
              Ro
              Same executable. Let me fire up the PI and see what's up.
              Z
                Originally posted by mattm55 View Post
                Hey guys,
                Thanks, Matt
                Will do, but I found another "issue" with the trouble/low battery since you mentioned it. Other than logging it, or having an event capture it, the plugin doesn't display a tamper/trouble or low battery issue in realtime, so I'm looking at what it will take to display it along with the status (ie Open/close, etc). Would also like the trigger to show what the actual alarm point is not just a general alarm.
                Did notice that the Concord plugin isn't listed in the Updater anymore, so have to see what that's about too..
                Z
                  Is there somewhere I can download the latest zip and use updater_override.txt?
                    Z
                    Looks like Dropbox isn't accepting http:// links for some reason. I've asked for ours to be updated to https://. I see several plugins that are not working now as well. It should be in the Updater once that's fixed.
                    Z
                      PM me your email address and I'll send you the direct dropbox link for the zip file.
                      Z
                        Pmd
                        Sent from my Samsung Galaxy Note 3
