Concord Plugin not working
  • Concord Plugin not working
    Hello,
    I've been using the Concord plugin 3.0.1.11 for over 8 months without any issues. Today, I updated the plugin to 3.1.13.2 and all problems started. It is not connecting to my panel, it displays "Comm Port Initialized. NOT Connected to Concord Panel" in the plugin configuration when I click connect. Tried many times restarting the server, the Concord security panel and the plugin, same problem, and when I click on Retrieve Zones, it creates a new set of incomplete devices, and says no zones found.
    I restored my Homeseer to my previous backup to get the 3.0.1.11 plugin, but now same problem. Cannot get this to work. Been on this all day long.
    Here is the log on startup:
    11/12/2015 5:09:47 PM ~!~Info~!~Plugin CONCORD has connected. IP:127.0.0.1:49256
    11/12/2015 5:09:47 PM ~!~CONCORD~!~---------------------------------------------------
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Initializing Concord, Vers:3.0.1.11
    11/12/2015 5:09:47 PM ~!~CONCORD Info~!~Initializing Concord DB
    11/12/2015 5:09:47 PM ~!~CONCORD Error~!~An unexpected error occurred in the InitConcord() function/subroutine: [System.TypeInitializationException: The type initializer for 'HSPI_CONCORD.dbModule' threw an exception. ---> System.DllNotFoundException: Unable to load DLL 'sqlite3': The specified module could not be found. (Exception from HRESULT: 0x8007007E) at System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(S QLiteConfigOpsEnum op) at System.Data.SQLite.SQLite3.StaticIsInitialized() at System.Data.SQLite.SQLiteLog.Initialize() at System.Data.SQLite.SQLiteConnection..ctor(String connectionString, Boolean parseViaFramework) at System.Data.SQLite.SQLiteConnection..ctor() at HSPI_CONCORD.dbModule..cctor() --- End of inner exception stack trace --- at HSPI_CONCORD.dbModule.InitDB() at HSPI_CONCORD.devModule.InitConcord()]
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Registering webpage [Control]
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Registering webpage [Configuration]
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Registering webpage [LogPage]
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Registering webpage [/html/CONCORD/Concord_help.htm]
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Registering webpage [HelpPage]
    11/12/2015 5:09:47 PM ~!~CONCORD~!~Check/Init Triggers
    11/12/2015 5:09:47 PM ~!~Plug-In~!~Finished initializing plug-in CONCORD
    11/12/2015 5:09:47 PM ~!~Info~!~Plugin HSTouch Server has connected. IP:127.0.0.1:49258
    11/12/2015 5:09:47 PM ~!~CONCORD Error~!~Error in PluginProc: Value cannot be null.Parameter name: source
    Here is my configuration:
    Current Date/Time: 11/12/2015 5:16:46 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.208
    Operating System: Microsoft Windows 7 Home Premium - Work Station
    System Uptime: 0 Days 0 Hours 7 Minutes 8 Seconds
    Number of Devices: 109
    Number of Events: 194
    Enabled Plug-Ins
    3.0.0.28: ADIO-100
    3.0.1.11: CONCORD
    3.0.0.75: HSTouch Server
    3.0.1.25: Z-Wave
    Attached are the screen shots with the devices when it "worked" and the new devices it creates that are not working. As you can see, the devices being created are individual vs together and these are zones with no assigned devices to them.
    Any help will be appreciated!
    Originally posted by Varouj View Post
    Hello,
    Enabled Plug-Ins
    3.0.0.28: ADIO-100
    3.0.1.11: CONCORD
    3.0.1.25: Z-Wave
    Stop the plugin, and then copy your System.Data.SQLite.dll from the /bin directory to the /bin/CONCORD directory and start the plugin again.
    Send me your HS startup log for the Concord plugin then.
    I'll PM you my email address.
    The updated plugin should have done all of that for you, but it may have missed a step due to permissions.
    Z
      just had the same issue... sorry but glad you posted this...
      I renamed my old hs install folder.. installed .218 .. (not in sig yet but old is)
      and concord plugin failed....
        Turn off existing plugin, then reinstall.
        Post the HS log of the Concord plugin startup if that doesn't resolve the issue.
        Z
          Z
          thx.. I was just posting saying it fixed my issue...
          thx!!!!
