After I updated the plugin, whenever I try to arm the alarm to stay from homelier it briefly sets to stay and changes to away. I have tried completely removing the plugin and recreating all the devices but it still happens. Anyone else see this problem?
Problem with Arm-Stay
Originally posted by markmm7 View PostAfter I updated the plugin, whenever I try to arm the alarm to stay from homelier it briefly sets to stay and changes to away. I have tried completely removing the plugin and recreating all the devices but it still happens. Anyone else see this problem?
What do you have checked off on the CONCORD Control Settings Page:
Arming Options: No Delay - Silent
User Code set ?
Remember Code set?
How are you Arming it? Manually, via event, etc
Z
Which version HS and Plugin?
HS3 Pro Edition 3.0.0.208 plugin version 3.1.13.2
Arming Options: No Delay - Silent both selected
User Code set ? Yes
Remember Code set? Yes
Both event and manually do the same thing. Arming directly at the panel is the only way I can get it to arm in Stay mode.
I rolled everything back to the previous version of the plugin and everything is arming correctly. Another thing I noticed is that with the new plugin, when arming the panel through HS I get something displayed on the physical alarm panel about Latchkey. That doesn't happen on the old version.
Originally posted by markmm7 View PostI rolled everything back to the previous version of the plugin and everything is arming correctly. Another thing I noticed is that with the new plugin, when arming the panel through HS I get something displayed on the physical alarm panel about Latchkey. That doesn't happen on the old version.
Z
Originally posted by vasrc View PostGood clues, I'll take a look here. Nothing has changed in the control section, so not sure what's occurring.
Z
Can you confirm what you see when you look at your HS3 device page for the Concord Control Panel on the Status Graphics tab?
There should be 4 settings at the top:
1 - Control - Disarm
1 - Status - Disarm
2 - Both - Armed Away
3 - Both - Armed Stay
PM me your email address and I'll give you a link to download a new EXE to test.
Z
