Concord 4 plugin not working
  • Concord 4 plugin not working
    Ok so I had the plugin working a bit go but went we went to .12 (think that was it) it broke and I was too busy to really bring it up and get into what is needed to fix.
    I built an identical machine and installed new OS and new HS install.
    Same issue..
    sooo here goes..
    Full HS Startup Log
    1/21/2016 10:59:06 PM ~!~Startup~!~Settings Loaded.
    1/21/2016 10:59:06 PM ~!~Startup~!~********************************************************************************
    1/21/2016 10:59:06 PM ~!~Startup~!~            HomeSeer version 3.0.0.208 Edition: HS3 Pro Starting Now
    1/21/2016 10:59:06 PM ~!~Startup~!~Creating Class Objects...
    1/21/2016 10:59:06 PM ~!~Startup~!~COM port classes started.
    1/21/2016 10:59:06 PM ~!~Startup~!~Application interface class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~Web server class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~E-Mail SEND class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~E-Mail RECEIVE class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~Plug-In Interface class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~HSPhone external interface class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~Local voice recognition class started.
    1/21/2016 10:59:06 PM ~!~Startup~!~Database SAVE process started.
    1/21/2016 10:59:06 PM ~!~Startup~!~Loading configuration file ...
    1/21/2016 10:59:06 PM ~!~Database~!~Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
    1/21/2016 10:59:06 PM ~!~Database~!~Loading Devices...
    1/21/2016 10:59:06 PM ~!~Load Config~!~27 total devices loaded.
    1/21/2016 10:59:06 PM ~!~Load Config~!~Loading Event Groups...
    1/21/2016 10:59:06 PM ~!~Load Config~!~Loading Events...
    1/21/2016 10:59:06 PM ~!~Load Config~!~0 total events loaded.
    1/21/2016 10:59:06 PM ~!~Load Config~!~Loading COUNTERS...
    1/21/2016 10:59:06 PM ~!~Load Config~!~Loading TIMERS...
    1/21/2016 10:59:06 PM ~!~Startup~!~HomeSeer version is: 3.0.0.208
    1/21/2016 10:59:06 PM ~!~Startup~!~Creating Speaker Client Interface Object...
    1/21/2016 10:59:06 PM ~!~Startup~!~This version of HomeSeer is not registered and is running as a trial, 23 days remaining.
    1/21/2016 10:59:06 PM ~!~Info~!~Remote plug-in API interface started on port 10400
    1/21/2016 10:59:06 PM ~!~Startup~!~Checking for available plug-ins
    1/21/2016 10:59:06 PM ~!~Plug-In~!~Found plug-in: BLRF, version: 2.0.83.0
    1/21/2016 10:59:06 PM ~!~Plug-In~!~Found plug-in: CONCORD, version: 3.1.13.4
    1/21/2016 10:59:06 PM ~!~Plug-In~!~Found plug-in: HSTouch Server, version: 3.0.0.75
    1/21/2016 10:59:06 PM ~!~Plug-In~!~Found plug-in: RFXCOM, version: 30.0.0.29
    1/21/2016 10:59:06 PM ~!~Plug-In~!~Found plug-in: X10, version: 3.0.0.36
    1/21/2016 10:59:06 PM ~!~Plug-In~!~Found plug-in: Z-Wave, version: 3.0.1.25
    1/21/2016 10:59:06 PM ~!~Startup~!~Initializing Plug-Ins
    1/21/2016 10:59:06 PM ~!~Info~!~Plugin CONCORD has connected. IP:127.0.0.1:62323
    1/21/2016 10:59:06 PM ~!~CONCORD Debug~!~isLinux = False
    1/21/2016 10:59:07 PM ~!~CONCORD~!~InitConcord() Initializing Concord, Vers:3.1.13.4
    1/21/2016 10:59:07 PM ~!~CONCORD Info~!~Initializing Concord DB
    1/21/2016 10:59:07 PM ~!~CONCORD Info~!~Loading Keypad table
    1/21/2016 10:59:07 PM ~!~CONCORD Info~!~LoadKeyPadTable() - filename=C:\Program Files (x86)\HomeSeer HS3\Data\CONCORD\keypadtable.txt
    1/21/2016 10:59:07 PM ~!~CONCORD Error~!~An unexpected error occurred in the InitConcord() function/subroutine:  [System.TypeInitializationException: The type initializer for 'HSPI_CONCORD.dbModule' threw an exception. ---> System.DllNotFoundException: Unable to load DLL 'sqlite3': The specified module could not be found. (Exception from HRESULT: 0x8007007E)   at System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(SQLiteConfigOpsEnum op)   at System.Data.SQLite.SQLite3.StaticIsInitialized()   at System.Data.SQLite.SQLiteLog.Initialize()   at System.Data.SQLite.SQLiteConnection..ctor(String connectionString, Boolean parseViaFramework)   at System.Data.SQLite.SQLiteConnection..ctor()   at HSPI_CONCORD.dbModule..cctor()   --- End of inner exception stack trace ---   at HSPI_CONCORD.dbModule.LoadKeypadTable()   at HSPI_CONCORD.devModule.InitConcord()]
    1/21/2016 10:59:07 PM ~!~CONCORD~!~---------------------------------------------------
    1/21/2016 10:59:07 PM ~!~Plug-In~!~Finished initializing plug-in CONCORD
    1/21/2016 10:59:07 PM ~!~Info~!~Plugin X10 has connected. IP:127.0.0.1:62325
    1/21/2016 10:59:07 PM ~!~ACT TI103~!~Calling initIO in TI103 with port:COM38
    1/21/2016 10:59:07 PM ~!~Info~!~TI103 Plug-in, Version 3.0.36
    1/21/2016 10:59:07 PM ~!~Plug-In~!~Finished initializing plug-in X10
    1/21/2016 10:59:07 PM ~!~Z-Wave Warning~!~Unknown Z-Wave Device Product Information Frequency value=U.S./CANADA/MEXICO.
    1/21/2016 10:59:07 PM ~!~Info~!~Plugin Z-Wave has connected. IP:127.0.0.1:62327
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~InitIO called, plug-in version 3.0.1.25 is being initialized...
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Loading Z-Wave Network Objects...
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~1 total Z-Wave Network Objects loaded.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Loading Z-Wave Data Objects...
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~1 Networks were restored from the data in the database... Building data connections.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Network 003D0B6B has 27 device data elements.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~27 total Z-Wave Data Objects loaded.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~0 event actions were loaded from HomeSeer.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~0 event triggers were loaded from HomeSeer.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Riggs Z-Troller: ======================================================================
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Riggs Z-Troller: ----------------------------------------------------------------------
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Initializing Z-Wave interface Riggs Z-Troller (HomeSeer Z-Troller) on COM36
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Riggs Z-Troller: The Z-Wave Command Execution Thread was Started or Restarted.
    1/21/2016 10:59:08 PM ~!~Plug-In~!~Finished initializing plug-in Z-Wave
    1/21/2016 10:59:08 PM ~!~Plug-In~!~Interface BLRF is running as a trial, 29 days remaining.
    1/21/2016 10:59:08 PM ~!~Info~!~Plugin BLRF has connected. IP:127.0.0.1:62329
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Riggs Z-Troller: The Z-Wave API Execution Thread was Started or Restarted.
    1/21/2016 10:59:08 PM ~!~Z-Wave~!~Riggs Z-Troller: Getting node information from controller...
    1/21/2016 10:59:08 PM ~!~BLRF start~!~Initializing BLRF...
    1/21/2016 10:59:08 PM ~!~BLRF start~!~BLRF version is: 2.0.83.0
    1/21/2016 10:59:08 PM ~!~BLRF start~!~Loaded configuration successfully
    1/21/2016 10:59:08 PM ~!~BLRF start~!~No security devices have been assigned to BLRF
    1/21/2016 10:59:08 PM ~!~BLRF start~!~No shadow devices have been assigned to BLRF
    1/21/2016 10:59:08 PM ~!~BLRF start~!~No sensor devices have been assigned to BLRF
    1/21/2016 10:59:08 PM ~!~BLRF start~!~BLRF plug-in has been initialized
    1/21/2016 10:59:08 PM ~!~Plug-In~!~Finished initializing plug-in BLRF
    1/21/2016 10:59:08 PM ~!~Info~!~Plugin HSTouch Server has connected. IP:127.0.0.1:62332
    1/21/2016 10:59:09 PM ~!~Plug-In~!~Finished initializing plug-in HSTouch Server
    1/21/2016 10:59:09 PM ~!~Web Server~!~Local IP address (subnet) is: 10.66.10.238 (255.255.0.0)
    1/21/2016 10:59:09 PM ~!~Web Server~!~UPNP Discovery started
    1/21/2016 10:59:09 PM ~!~Web Server~!~Web Server started on port 81
    1/21/2016 10:59:09 PM ~!~Startup~!~Creating ASP.NET application host...
    1/21/2016 10:59:09 PM ~!~Startup~!~Start automation engine...
    1/21/2016 10:59:09 PM ~!~Startup~!~Initializing Speaker Client Interface
    1/21/2016 10:59:09 PM ~!~Speech~!~Listening for remote speaker connections on port 10401
    1/21/2016 10:59:09 PM ~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
    1/21/2016 10:59:09 PM ~!~Startup~!~Updater services starting...
    1/21/2016 10:59:09 PM ~!~Startup~!~Starting DDNS service...
    1/21/2016 10:59:09 PM ~!~Info~!~Starting speaker client...
    on server
    HS window
    Waiting for user to continue trial...
    Starting up....
    1/21/2016 10:59:07 PM ~!~CONCORD Error~!~An unexpected error occurred in the InitConcord() function/subroutine:  [System.TypeInitializationException: The type initializer for 'HSPI_CONCORD.dbModule' threw an exception. ---> System.DllNotFoundException: Unable to load DLL 'sqlite3': The specified module could not be found. (Exception from HRESULT: 0x8007007E)   at System.Data.SQLite.UnsafeNativeMethods.sqlite3_config_none(SQLiteConfigOpsEnum op)   at System.Data.SQLite.SQLite3.StaticIsInitialized()   at System.Data.SQLite.SQLiteLog.Initialize()   at System.Data.SQLite.SQLiteConnection..ctor(String connectionString, Boolean parseViaFramework)   at System.Data.SQLite.SQLiteConnection..ctor()   at HSPI_CONCORD.dbModule..cctor()   --- End of inner exception stack trace ---   at HSPI_CONCORD.dbModule.LoadKeypadTable()   at HSPI_CONCORD.devModule.InitConcord()]Startup Complete, 1 errors detected, check the log for more information.
    HS stuff
    Current Date/Time: 1/21/2016 11:03:15 PM
     HomeSeer Version: HS3 Pro Edition 3.0.0.208
     Operating System: Microsoft Windows Server 2012 R2 Essentials - Domain Controller
     System Uptime: 0 Days 0 Hours 4 Minutes 9 Seconds
     IP Address: 10.66.10.238
     Number of Devices: 27
     Number of Events: 0
    Enabled Plug-Ins
     2.0.83.0: BLRF
     3.1.13.4: CONCORD
     3.0.0.75: HSTouch Server
     3.0.0.36: X10
     3.0.1.25: Z-Wave
    What really confuses me is that I can click connect... but it fails... BUT I HAVE MY ALARM INFO!!!!! it is weird like it is connecting but then disconnecting?
    Same issue..
    sooo here goes..
    Full HS Startup Log
    on server
    HS window
    Starting up....
    HS stuff
     Number of Events: 0
    Enabled Plug-Ins
     2.0.83.0: BLRF
     3.1.13.4: CONCORD
     3.0.0.36: X10
     3.0.1.25: Z-Wave
    Good info.
    Still the same issue, SQLite isn't running, so you're not getting any of the configuration from the DB. This is why the PI works, but not completely.
    I'm guessing your don't have the sqlite3.dll in the HS3 root directory after all of the new instals.
    Try placing this dll file there and LMK
    https://dl.dropboxusercontent.com/u/...er/sqlite3.dll
    Z
      you rock that did it!!!!
      thx
