I have a new version ready that fixes a long time bug with the Stay/Away status.
I've also added a Bypass confirm action to acknowledge any Bypass protests when arming the system.
Arm Away now uses the Silent checkbox the same as Arm Stay does. I did have a question that doing that might cause an issue, but since it would ONLY be when you arm from HS3 and not from the keypad, I figured it would be OK.
I'll be posting the new version in the Updater, but this version may cause some issues with events since the Panel Control device needs to be deleted (the PI will restore it correctly). If you have any events linked to that status, they will need to relink it in that event.
I'll post a Dropbox link to download just the EXE file for those already running installed version. New installs shouldn't have that issue since they don't have events linked yet.
Any other changes??
Z
Any other changes??
Z
