Looking to integrate Concord System
  • #16
    Originally posted by vasrc View Post
    Couple of things..
    1. Is the sqlite3.dll file in the HS3 root directory?
    2. Try using Odd parity
    3. Are you sure the USB/Serial device is a DTE device (Pin 3 should show voltage (approx 5vdc). If not, then you'll need a null modem cable.
    I've just uploaded the latest Version 1_13_6, it has the sqlite3.dll file in it now.
    Z
    1. No sqlite3.dll in HS3 Root directory
    2. I tried Odd polarity. It became green and said "Connected to Concord 4". Then I went to retrieve zones and it went back to "Comm Port Initialized. NOT Connected to Concord Panel"
    3. Multi-meter shows 6.34V between pin 3 and 5.
    Is there a location for the download of 1_13_6 or do I wait until it shows up in updater?
    • #17
      It should already show up there. Try clicking on "Update Listing"
      It won't connect until you have the SQLite db accessed.
      Z
      • #18
        Looks like everything is working! As an FYI, the latest version is 5 and not 6, but 6 still shows in updater. I went from v4 to v5.
        Thanks for the help!
        • #19
          HS takes sometime to recognize the new version # sometimes. It should change to 6 shortly.
          Glad to hear it's working now.
          Z
          • #20
            It appears the "panel control" device's "status graphics" page has Arm Stay and Arm Away swapped. I needed to set value 2 to Arm Stay and 3 to Arm Away. It was the other way originally.
            Not sure if this was just my system or if the plugin created it incorrectly.
            • #21
              It was one of the changes in Vers 6. Try deleting that device and it should be recreated correctly.
              Z
              • #22
                Z
                I just tried to update to 6 and I clicked the check mark to update and it says everything went correctly. Then when it refreshes the 6 version is still saying it is available. 5 is still stated when I do the update....
                Apr-22 9:10:51 PM	 	CONCORD	InitConcord() Initializing Concord, Vers:3.1.13.5
                • #23
                  This is the full log of update:
                  Apr-22 9:10:56 PM	 	Plug-In	Finished initializing plug-in CONCORD
                  Apr-22 9:10:56 PM	 	CONCORD	---------------------------------------------------
                  Apr-22 9:10:56 PM	 	CONCORD	Concord Initialization Complete!
                  Apr-22 9:10:55 PM	 	CONCORD	Check/Init Triggers
                  Apr-22 9:10:55 PM	 	CONCORD	Initializing COM3
                  Apr-22 9:10:55 PM	 	CONCORD Info	Initializing Timers
                  Apr-22 9:10:54 PM	 	CONCORD Info	Validating Zones/Devices
                  Apr-22 9:10:53 PM	 	CONCORD Info	Loading Zone Data from Database to memory
                  Apr-22 9:10:53 PM	 	CONCORD Info	Loading Zone Types
                  Apr-22 9:10:53 PM	 	CONCORD	Configuration Checks Complete
                  Apr-22 9:10:53 PM	 	CONCORD	Getting Concord Configuration
                  Apr-22 9:10:53 PM	 	CONCORD Info	Checking/Updating DB configuration
                  Apr-22 9:10:53 PM	 	CONCORD Info	Verifying User/Tracking tables
                  Apr-22 9:10:53 PM	 	CONCORD Info	Adding default Concord Plugin user(250)
                  Apr-22 9:10:53 PM	 	CONCORD Info	Adding default Concord Plugin user(255)
                  Apr-22 9:10:52 PM	 	CONCORD Info	Retrieving User Data
                  Apr-22 9:10:52 PM	 	CONCORD Info	Loading settings from hspi_Concord.ini
                  Apr-22 9:10:52 PM	 	CONCORD Info	LoadKeyPadTable() - filename=C:\Program Files (x86)\HomeSeer HS3\Data\CONCORD\keypadtable.txt
                  Apr-22 9:10:51 PM	 	CONCORD Info	Loading Keypad table
                  Apr-22 9:10:51 PM	 	CONCORD Info	Initializing Concord DB
                  Apr-22 9:10:51 PM	 	CONCORD Debug	isLinux = False
                  Apr-22 9:10:51 PM	 	Info	Plugin CONCORD has connected. IP:127.0.0.1:52041
                  Apr-22 9:10:50 PM	 	Updater	Re-initializing plugin after update.
                  Apr-22 9:10:50 PM	 	Updater	Install/Update of package Concord 4 Security Panel was successful.
                  Apr-22 9:10:50 PM	 	Updater	Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_CONCORD.exe.config
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\sqlite3.dll
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\bin\CONCORD\SQLite.Interop.dll
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\bin\CONCORD\System.Data.SQLite.dll
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Data\CONCORD\keypadtable.txt
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Data\CONCORD\CONCORDDB3.db
                  Apr-22 9:10:50 PM	 	Updater	Copying file: C:\Program Files (x86)\HomeSeer HS3\html\CONCORD\Concord_help.htm
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Logs\CONCORD\CONCORD_default.log
                  Apr-22 9:10:50 PM	 	Updater Warning	File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\hspi_Concord.ini
                  Apr-22 9:10:50 PM	 	Updater	Extraction Complete.
                  Apr-22 9:10:50 PM	 	Updater	Extracting files from zip file: C:\Program Files (x86)\HomeSeer HS3\Updates3\Concord 4 Security Panel3.1.13.6\CONCORD_images.zip Destination: C:\Program Files (x86)\HomeSeer HS3\html\images\CONCORD\
                  Apr-22 9:10:43 PM	 	Updater	Installing package Concord 4 Security Panel
                  Apr-22 9:10:43 PM	 	Updater	Update HSPI_CONCORD.exe downloaded successfully
                  Apr-22 9:10:41 PM	 	Updater	Downloading update: Concord 4 Security Panel
                  • #24
                    Not sure if it's just the internal vers notation, or it didn't include in the Updater, so use this while I see why it's not there. Just replace the HSPI_CONCORD.exe file (stop the plugin first of course)
                    https://dl.dropboxusercontent.com/u/...PI_CONCORD.exe
                    Then delete the device. It should recreate correctly.
                    LMK,
                    Z
                    • #25
                      Found it.. The upload should now have Vers 6 in it
                      Z
                      • #26
                        Thanks. Now it shows 6 in the log and the device was created correctly.
                        • #27
                          Concord 4 Comm Port Initialized. NOT Connected to Concord Panel
                          Hi Everyone I was reading the forums but couldnt find a correct answer to my problem:
                          I have a Concord 4 connected to HS3 thru a usb-serial adapter
                          evrything workgs great for few hours but then i lose connection and the error i got is:
                          the only way to get the connection back is to disconnect and reconnect the usb-serial adapter, any ideas what it can be?
                          this is the log:
                          CONCORD Aug 26, 2016 4:33:45 PM Closing Comm Port Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 1:33:07 PM Communications Lost Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 1:01:59 PM Normal Zone 1 FRONT DOOR Partition 1
                          CONCORD Aug 26, 2016 11:30:00 AM Normal Zone 1 FRONT DOOR Partition 1
                          CONCORD Aug 26, 2016 10:45:43 AM Communications Initialized Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 10:44:43 AM Communications Lost Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 10:29:33 AM Communications Restored Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 10:29:22 AM Initializing Comm Port Zone Chime Partition 1 CONCORD Aug 26, 2016 9:52:52 AM Communications Restored Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 9:52:42 AM Initializing Comm Port Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 12:08:42 AM Communications Restored Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 12:08:31 AM Initializing Comm Port Zone 205 Connection Status Partition 1 C
                          ONCORD Aug 26, 2016 12:01:19 AM Communications Restored Zone 205 Connection Status Partition 1
                          CONCORD Aug 26, 2016 12:01:09 AM Initializing Comm Port Zone 205 Connection Status Partition 1
                          Thanks in adavance for your help
                          • #28
                            do you have a onboard serial port you could switch out to test against?
                            I have a serial port and used that for my alarm. Then I also added 2 x pci dual serial cards for more ports as I try to avoid usb adapters but that is just me...
                            • #29
                              Thanks for posting, I am using a usb adapter, I tried 2 different ones the last one looks like is working better I guess I will buy a pci adapter and give it a try.
                              I didnt have much faith on the usb adapter to beging with, do you recommend any particular serial pci card? Thanks
                              • #30
                                I use the Edgeport 4 port serial to usb thats documented in the doc. I has work flawlessly for me.
                                Set and forget. Others can weigh in on their hw with sucess. I got mine used on fleabay with all cables.
                                Matt
