I'm having no luck connecting to my Comfort Alarm panel. I'm using a serial UCM and have tried configuring for USB and serial with no luck. Any pointers please? The setup I use works fine with a legacy V2 Homeseer Plugin.
Can't Connect to Panel
Hmm difficult to say. Those USB names looking strange to me. Are you running HS on windows? The plugin is only tested on windows as i don't have linux-based HS. It uses the same libraries as Comfigurator so if you are able to connect from comfigurator on the HS system you should also be able to connect from within the plugin.
Originally posted by posixx View PostHmm difficult to say. Those USB names looking strange to me. Are you running HS on windows? The plugin is only tested on windows as i don't have linux-based HS. It uses the same libraries as Comfigurator so if you are able to connect from comfigurator on the HS system you should also be able to connect from within the plugin.
Here is the output from the plugin window:
Plugin: Cytech Comfort Instance: starting...
Connecting to server at 127.0.0.1...
Host API Version: 3
Connected, waiting to be initialized...
Starting Comfort plugin initialization.
That's it I'm afraid when I press connect in the config no other messages or anything. Like I said this works fine with the comfigurator using com6 (serial).
Originally posted by IanIreland View PostI am aware of other applications that don't 'behave' properly with USB converters. I would be tempted to put a copy of Homeseer on a physical machine and then see it it works.
Sent from my SM-G960F using Tapatalk
Originally posted by posixx View PostWhat devices (ports) are listed in device manager on the VM you run the plugin on? And what brand of USB-serial converter you use? Also what settings you use in the legacy plugin?
