Status of door sensor changing
  • Status of door sensor changing
    I have the Envisalinkademco plugin ver 3.0.0.24 and the evl 3 interface.
    I have some events that trigger only when door sensors change status (open or close) which sends an email. The events have been working fine for about 8 months. If one door opened it sent an email stating its open and another one when it closed. In the past week however when a door stays open the status in Homeseer will go from open to close and back every few seconds and send emails. The envisalink logs do not show the door closing but Homeseer is reporting it. Any ideas?
    Thanks.
    If the EnvisaLink log does not show the door closing, then it's not this plug-in that trigger the device change. Make sure log is enabled for this particular device and confirm that the change does not come from the plug-in. If this is the case then you need to look for another plugin or script that could change the device value by mistake.
      Hi Spud, I enabled debug logging and this is what I have. I opened the door and left it that way at 10:56am and didn't close it until 10:58. When I said that the envisalink log didn't show the door opening and closing multiple times I was referring to the eyez-on web page, it didnt show the false open and close status like homeseer does. Since it doesn't show the erroneous opening and closings I assumed its with the plugin since it interfaces directly with the evl 3. Does this log snip give you any ideas that I can try? As far as I know nothing has changed for this to start happening. The status of door sensors always reported correctly and stayed correct until a change happened which allowed the changes and becomes triggers to work. Thanks.
      5/18/2017
      May-18 10:56:21 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:21 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:21 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:21 AM EnvisaLinkAdemco DEBUG Received: %FF,0000E5FEFCFF00000000000000000000000020FF000000000000FCFF 00008BFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:21 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000E5FEFCFF00000000000000000000000020FF000000000000FCFF0000 8BFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:23 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:56:23 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:56:26 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:26 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:26 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:26 AM EnvisaLinkAdemco DEBUG Received: %FF,0000E4FEFBFF0000000000000000000000001FFF000000000000FBFF 00008AFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:26 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000E4FEFBFF0000000000000000000000001FFF000000000000FBFF0000 8AFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:27 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:56:27 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,94,00,Telco Fault $
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,94,00,Telco Fault
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG Received: %FF,0000E3FEFAFF0000000000000000000000001EFF000000000000FDFF 000089FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:31 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000E3FEFAFF0000000000000000000000001EFF000000000000FDFF0000 89FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:31 AM EnvisaLinkAdemco INFO Motion status change: Closed
      May-18 10:56:35 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,00,00,CHECK 100 RF RECEIVER $
      May-18 10:56:35 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,00,00,CHECK 100 RF RECEIVER
      May-18 10:56:36 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:36 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:36 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:36 AM EnvisaLinkAdemco DEBUG Received: %FF,0000E2FEF9FF0000000000000000000000001DFF000000000000FCFF 000088FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:36 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000E2FEF9FF0000000000000000000000001DFF000000000000FCFF0000 88FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:39 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:56:39 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:56:41 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:41 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:41 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:41 AM EnvisaLinkAdemco DEBUG Received: %FF,0000E1FEF8FF0000000000000000000000001CFF000000000000FBFF 000087FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:41 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000E1FEF8FF0000000000000000000000001CFF000000000000FBFF0000 87FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:41 AM EnvisaLinkAdemco INFO Deck Door status change: Closed
      May-18 10:56:43 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:56:43 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
      May-18 10:56:46 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:46 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:46 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:46 AM EnvisaLinkAdemco DEBUG Received: %FF,0000E0FEF7FF0000000000000000000000001BFF000000000000FDFF 000086FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:46 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000E0FEF7FF0000000000000000000000001BFF000000000000FDFF0000 86FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:46 AM EnvisaLinkAdemco INFO Deck Door status change: Opened
      May-18 10:56:47 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,94,00,Telco Fault $
      May-18 10:56:47 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,94,00,Telco Fault
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,00,00,CHECK 100 RF RECEIVER $
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,00,00,CHECK 100 RF RECEIVER
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG Received: %FF,0000DFFEF6FF0000000000000000000000001AFF000000000000FCFF 000085FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:51 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000DFFEF6FF0000000000000000000000001AFF000000000000FCFF0000 85FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:55 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:56:55 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:56:56 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:56:56 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:56:56 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:56:56 AM EnvisaLinkAdemco DEBUG Received: %FF,0000DEFEF5FF00000000000000000000000019FF000000000000FBFF 000084FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:56:56 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000DEFEF5FF00000000000000000000000019FF000000000000FBFF0000 84FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:56:56 AM EnvisaLinkAdemco INFO Deck Door status change: Closed
      May-18 10:56:59 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:56:59 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
      May-18 10:57:01 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:01 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:01 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:01 AM EnvisaLinkAdemco DEBUG Received: %FF,0000DDFEF4FF00000000000000000000000018FF000000000000FDFF 000083FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:01 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000DDFEF4FF00000000000000000000000018FF000000000000FDFF0000 83FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:01 AM EnvisaLinkAdemco INFO Deck Door status change: Opened
      May-18 10:57:02 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,94,00,Telco Fault $
      May-18 10:57:02 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,94,00,Telco Fault
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG Received: %FF,0000DCFEF3FF00000000000000000000000017FF000000000000FCFF 000082FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000DCFEF3FF00000000000000000000000017FF000000000000FCFF0000 82FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,00,00,CHECK 100 RF RECEIVER $
      May-18 10:57:06 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,00,00,CHECK 100 RF RECEIVER
      May-18 10:57:10 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:57:10 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:57:11 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:11 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:11 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:11 AM EnvisaLinkAdemco DEBUG Received: %FF,0000DBFEF2FF00000000000000000000000016FF000000000000FBFF 000081FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:11 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000DBFEF2FF00000000000000000000000016FF000000000000FBFF0000 81FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:11 AM EnvisaLinkAdemco INFO Deck Door status change: Closed
      May-18 10:57:14 AM EnvisaLinkAdemco DEBUG Received: %01,0020000000000000$ %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:57:14 AM EnvisaLinkAdemco DEBUG ZoneStateChange 0020000000000000
      May-18 10:57:14 AM EnvisaLinkAdemco INFO Deck Door status change: Opened
      May-18 10:57:14 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
      May-18 10:57:16 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:16 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:16 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:16 AM EnvisaLinkAdemco DEBUG Received: %FF,0000DAFEF1FF00000000000000000000000015FF000000000000FDFF 000080FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:16 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000DAFEF1FF00000000000000000000000015FF000000000000FDFF0000 80FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:18 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,94,00,Telco Fault $
      May-18 10:57:18 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,94,00,Telco Fault
      May-18 10:57:21 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:21 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:21 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:22 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D9FEF0FF00000000000000000000000014FF000000000000FCFF 00007FFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:22 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D9FEF0FF00000000000000000000000014FF000000000000FCFF0000 7FFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:22 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,00,00,CHECK 100 RF RECEIVER $
      May-18 10:57:22 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,00,00,CHECK 100 RF RECEIVER
      May-18 10:57:26 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:26 AM EnvisaLinkAdemco DEBUG Received: ^02,00$ %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:57:26 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:26 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:57:27 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D8FEEFFF00000000000000000000000013FF000000000000FBFF 00007EFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:27 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D8FEEFFF00000000000000000000000013FF000000000000FBFF0000 7EFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:27 AM EnvisaLinkAdemco INFO Deck Door status change: Closed
      May-18 10:57:30 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:57:30 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
      May-18 10:57:31 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:31 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:31 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:32 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D7FEEEFF00000000000000000000000012FF000000000000FDFF 00007DFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:32 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D7FEEEFF00000000000000000000000012FF000000000000FDFF0000 7DFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:32 AM EnvisaLinkAdemco INFO Deck Door status change: Opened
      May-18 10:57:34 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,94,00,Telco Fault $
      May-18 10:57:34 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,94,00,Telco Fault
      May-18 10:57:36 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:36 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:36 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:37 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D6FEEDFF00000000000000000000000011FF000000000000FCFF 00007CFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:37 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D6FEEDFF00000000000000000000000011FF000000000000FCFF0000 7CFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:38 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,00,00,CHECK 100 RF RECEIVER $
      May-18 10:57:38 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,00,00,CHECK 100 RF RECEIVER
      May-18 10:57:41 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:41 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:41 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:42 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D5FEECFF00000000000000000000000010FF000000000000FBFF 00007BFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:42 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D5FEECFF00000000000000000000000010FF000000000000FBFF0000 7BFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:42 AM EnvisaLinkAdemco INFO Deck Door status change: Closed
      May-18 10:57:42 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:57:42 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:57:46 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:46 AM EnvisaLinkAdemco DEBUG Received: ^02,00$ %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:57:46 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:46 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
      May-18 10:57:47 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D4FEEBFF0000000000000000000000000FFF000000000000FEFF 00007AFE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:47 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D4FEEBFF0000000000000000000000000FFF000000000000FEFF0000 7AFE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:47 AM EnvisaLinkAdemco INFO Deck Door status change: Opened
      May-18 10:57:50 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,94,00,Telco Fault $
      May-18 10:57:50 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,94,00,Telco Fault
      May-18 10:57:51 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:51 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:51 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:52 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D3FEEAFF0000000000000000000000000EFF000000000000FDFF 000079FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:52 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D3FEEAFF0000000000000000000000000EFF000000000000FDFF0000 79FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:54 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,00,00,CHECK 100 RF RECEIVER $
      May-18 10:57:54 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,00,00,CHECK 100 RF RECEIVER
      May-18 10:57:56 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:57:56 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:57:56 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:57:57 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D2FEE9FF0000000000000000000000000DFF000000000000FCFF 000078FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:57:57 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D2FEE9FF0000000000000000000000000DFF000000000000FCFF0000 78FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:57:58 AM EnvisaLinkAdemco DEBUG Received: %00,01,0208,BF,00,CHECK 103 LngRngRadio 0000$
      May-18 10:57:58 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0208,BF,00,CHECK 103 LngRngRadio 0000
      May-18 10:58:01 AM EnvisaLinkAdemco DEBUG Request: DumpZoneTimers
      May-18 10:58:01 AM EnvisaLinkAdemco DEBUG Received: ^02,00$
      May-18 10:58:01 AM EnvisaLinkAdemco DEBUG CommandAck 02,00
      May-18 10:58:02 AM EnvisaLinkAdemco DEBUG Received: %FF,0000D1FEE8FF0000000000000000000000000CFF000000000000FBFF 000077FE0000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 00000000000000000000$
      May-18 10:58:02 AM EnvisaLinkAdemco DEBUG EnvisaLinkZoneTimerDump 0000D1FEE8FF0000000000000000000000000CFF000000000000FBFF0000 77FE00000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000000000000000000000 0000000000000000
      May-18 10:58:02 AM EnvisaLinkAdemco INFO Deck Door status change: Closed
      May-18 10:58:02 AM EnvisaLinkAdemco DEBUG Received: %00,01,0008,14,00,FAULT 14 MAIN DECK DOOR $
      May-18 10:58:02 AM EnvisaLinkAdemco DEBUG VirtualKeypadUpdate 01,0008,14,00,FAULT 14 MAIN DECK DOOR
        you logs show that your keypad report the following messages:
        I'm not sure what they mean exactly (some kind of trouble on your system), but I guess it is the cause of your problem.
        I know it seems strange this could cause such a problem, but here is some explanations:
        the envisalink board does not report to the plugin when a zone is closed, so the plugin uses a complex logic based on timers and keypad updates to infer this information, this can become very tricky when several zones are opened or when other messages are reported by the keypad, and leads to bugs like this.
        so maybe you can try to fix those troubles detected on your system, otherwise one workaround is to edit EnvisaLinkAdemco.ini, and add the following parameter in the PANEL section
        [PANEL]
        keypad_update_interval = 10
        The default value is 5, making it 10 or 15 should fix your problem, but it will increase the delay before the plugin considers a zone closed.
          Spud, it looks like it was the radio errors that were causing the issue. After I cleared them things are back to normal. I played with the ini file and that caused issues with reliability so I set it back to 5. Thanks for your help.
