Not setting Partition Mode - but status works?
  • Not setting Partition Mode - but status works?
    UPDATE: I verified the EVL & Panel are working perfectly... I hooked up the Vera again, no problems at all controling from Vera.
    In HS3... status of connected panel devices show properly (motion, door/window) and panel status) -- BUT control (setting 'Partition 1' ) using the HS3 GUI, does nothing at all.
    I have looked at everything I know and tried restarting the EVL3. The plugin connects to and shows status for the EVL3 but it does not control anything. The EVL site shows the TPI connection to the HS3 IP Address as expected.
    Debug logged attached
    Sorry for the delay (I'm on vacation)
    Double check the security code you set in the config page, it needs to be a code that you can use to arm and disarm the panel from a keypad.
      Thx - That was it - sorry, I thought I had set that!
