Trigger an event based on Disarm
  • Trigger an event based on Disarm
    Spud,
    Is there a way to trigger an event based upon the system being disarmed? Partition 1 allows you to manually disarm the system, but disarm is not an available status in the events. Can i simply change it to a "both status/control" or is there another way to see that the system has been disarmed?
    Sorry if i'm asking something that is answered elsewhere, i just didn't see it.
    read this thread: https://forums.homeseer.com/showthread.php?t=171905
    an alternative solution to trigger based on disarm, would be to use the EasyTrigger "This device's value was and becomes..."
      Here is how I am doing it, if this helps
          I am seeing it as part of the Envisalink plugin in the drop down
            I don't have that option?
Name:	Screen Shot 2017-11-08 at 12.54.07 PM.png
            I'm using version 3.0.0.28 of the EnvisaLinkAdemco plugin
              Same, I don't see it either. Do you have a DSC or Ademco panel?
              I'm on an Ademco panel. The Ademco panel's communication with Envisalink is limited when compared to the DSC panel.
              Jim
                Update your plugin and then check again. I am on .37
                  Jim
                  I have the DSC 1864 panel.
                    Jim
                    Ademco
                      Well now I see... and sorry for the wild goose chase. I didn't see this isn't for the DSC panel. I just saw envisalink and went with it.
                        .27 is the newest Ademco plugin. DSC is at .38 - so i guess that feature isn't available for the Ademco plugin?
                          Probably do to the limited feature set the Ademco panels provide to the Envisalink.
                          I was going to go with a DSC panel when I replaced my alarm panel. The only reason I went with the Ademco panel is because the standard DSC keypads were not large enough to entirely cover the wall where the old keypads were.
                          WAF unacceptable.
                          Jim
