Hi Spud,
I just iinstalled the ademco app and I can't seem to get it to login. I'll attach a log below. I tried resetting the password on eyeson and i can login there and control my panel but just not in homeseer. It keeps saying bad password. I looked at the ini and it appears to be correct. I've even tried making the password longer, truncated it etc.. But to no avail. Can you give me any hints to try next. I want this plugin for sure if I can get it up and running. I've even uninstalled, wiped out the ini and reinstalled.
See log, I will edit out the password.
Thanks!
EnvisaLinkAdemco INFO Unable to execute request - Not Connected
Feb-05 7:32:41 AM EnvisaLinkAdemco DEBUG Request: SendKeystrokeString ****1
Feb-05 7:32:41 AM Device Control Device: EnvisaLinkAdemco Partition 1 to Disarm (-1005) by/from: CAPI Control Handler
Feb-05 7:32:09 AM Device Control Device: Garage Garage Coach Lights to Off (0)
Feb-05 7:32:09 AM Device Control Device: Front Door Outside Front Light to Off (0)
Feb-05 7:32:09 AM Device Control Device: Front Coach Lights Outside Lights to Off (2)
Feb-05 7:32:09 AM Event Event Trigger "Outside Lights Coach Lights Off in Morning"
Feb-05 7:31:29 AM EnvisaLinkAdemco INFO Unable to execute request - Not Connected
Feb-05 7:31:29 AM EnvisaLinkAdemco DEBUG Request: SendKeystrokeString ****3
Feb-05 7:31:29 AM Device Control Device: EnvisaLinkAdemco Partition 1 to Arm Stay (-1000) by/from: CAPI Control Handler
Feb-05 7:31:10 AM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: http://download.dedroog.com/hs3/Buienradar/updater.txt
Feb-05 7:31:00 AM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: http://download.dedroog.com/hs3/Pushalot/updater.txt
Feb-05 7:30:55 AM Updater An item in the Updater is temporarily unavailable: The operation has timed out Item: http://download.dedroog.com/hs3/FritzTR064/updater.txt
Feb-05 7:30:50 AM Plug-In Finished initializing plug-in EnvisaLinkAdemco
Feb-05 7:30:50 AM EnvisaLinkAdemco ERROR Thread was interrupted from a waiting state.
Feb-05 7:30:50 AM EnvisaLinkAdemco ERROR Wrong password
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Received: FAILED
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Request: SendKeystrokeString ******
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Received: Login:
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:22
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:21
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:20
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:19
Feb-05 7:30:49 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:18
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:17
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:16
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:15
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:14
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:13
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:12
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:11
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:10
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:9
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:8
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:7
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:6
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:5
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:4
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:3
Feb-05 7:30:48 AM EnvisaLinkAdemco DEBUG Zone Device Found: Z:2
Feb-05 7:30:45 AM EnvisaLinkAdemco DEBUG User Access Device Found: U:1
Feb-05 7:30:43 AM EnvisaLinkAdemco DEBUG Partition Device Found: P:1
Feb-05 7:30:38 AM EnvisaLinkAdemco INFO EnvisaLinkAdemco version 3.0.0.29
Feb-05 7:30:37 AM Info Plugin EnvisaLinkAdemco has connected. IP:127.0.0.1:50729
Feb-05 7:30:35 AM Plug-In Interface EnvisaLinkAdemco is running as a trial, 29 days remaining.
Thanks!
