Please help with EnvisaLink Ademco Plug-in event.
  • Please help with EnvisaLink Ademco Plug-in event.
    I have an event that is triggered thus:
    If EnvisaLinkAdemco Root had its value set to Disarmed
    and IF Ademco Loft Balcony door is Closed
    then .....
    It has suddenly started triggering repeatedly with no change in the arming/disarming of system or opening/closing of door. Security system is vista.
    For a while it triggered every 10 seconds on the nose. I rebooted the envisalink and now it's triggering every 4 seconds. If I disconnect the envisalink from the network, the triggering stops.
    Has anyone seen something like this or have an idea how I can fix?
    Thanx!
    Can you use "changes and becomes" Disarmed instead? The "value set to" trigger happens every time its updated, not just when it changes state.
      I'll try that. But I've used this event for some time and it worked fine until recently.
